Hi All
Have been a muppet and need to source / buy / borrow locally for SVA on Tuesday (so by Monday night !)
2x 12mm fine (1mm pitch ?) nuts for seatbelt floor bolts, and
an electronic three pin flasher relay / unit suitable for running LED indicators
Any help gratefully received !!
Simon
Yep, spotted my deliberate mistake haven't you !!
I'm right in the spot where Beds, Cambs and Herts collide - a little village called Wrestlingworth.
I've sorted the harness nuts, have a great old fashioned hardware store in Biggleswade and he took one look at the bolts and came back with the
right nuts first time.
Just need a solution for my fast flashers !!
Simon
Simon
If you haven't sorted the flashers it may be possible to wire some bulbs or resistance in to be able to use a non LCD flasher unit as a temporary measure? Hope you read this in time.
Hi there - I had an electronic flasher unit delivered to the testing station but was academic as we couldn't complete the test as you will see
from my other post !!
Thanks for the suggestion.
Simon
