Fs: All sorts!
Yazza54 - 27/10/11 at 06:09 PM
Right heres a collection of stuff I've had in my bedroom that I no longer need....
DogCam Mini DVR III Bullet camera system - £130
Complete with suction mounts and a clip on type, 2 batteries, mains charger, cigarette lighter charger, sony bullet camera, DVR recorder, original box + instructions. Reasonably priced bullet cam setup! Micro SD card compatible up to 32GB. Used a few times with good results, ended up selling my kit car, don't really need it anymore.
Road angel plus - £35 posted
Bought when I had my GTM Libra, no box, comes with charger for mains and cig lighter. Does need updating to current camera locations but regardless of this it has the infra red so will pick up cameras that way.
5PW Yamaha R1 2002-2003 may fit 5JJ too? - £4 each
2x new stretch bolts to stator generator/flywheel - if your charging system burns out and the flywheel is removed to repair it you will need new stretch bolts. These will come loose at some point if re-used.
2x new stator generator/flywheel case gaskets - if you don't use a gasket and try using sealant it WILL leak oil. I learned the hard way!!
All proceeds go to me spanking my bike on my IOM TT2012 trip. KING OF THE MOUNNTAAAAAINNNNN!
Yazza54 - 27/10/11 at 06:56 PM
Dogcam sold
Yazza54 - 28/10/11 at 06:55 AM
Bump!
Yazza54 - 1/11/11 at 12:36 PM
Bump
coyoteboy - 2/11/11 at 11:11 PM
Sorry, can't let that slip - you can't yell king of the mountain unless you're a road bike rider and pedal up a mountain, it's the law
