Westfield 1987 Pre-Lit fitted with alloy bodywork, On SORN matching chassis numbers Alloy Caterham bonnet ,scuttle with GRP nose cone. Floor mounted
pedal box bias brake , cable clutch. Quick rack, Down link and steering column. Wide track front suspension, Cortina front uprights with alloy hubs
– long studs. carbon aerosceen. English axle in need of refurbishment. Some competition history prior to re-build £2850.00
Westfield SEi 1990 with a 1989 Chassis number. On SORN Matching chassis numbers front and rear anti roll bars, Full “Caged “with side impact bars
Green tub with lightweight bonnet and nose cone with spare bonnet (high level ) High level areo screen . Floor mounted pedal box with bias brake and
Hyd Clutch. Removable steering wheel, column and down link with quick rack. HD Drive Shafts, Disc brake rear upright Would make great road or track
day car £3000.00
Need the space. Please email for photos.
Neil on 01738 55005
Pmsent
Originally posted by NDS
Westfield 1987 Pre-Lit fitted with alloy bodywork, On SORN matching chassis numbers Alloy Caterham bonnet ,scuttle with GRP nose cone. Floor mounted pedal box bias brake , cable clutch. Quick rack, Down link and steering column. Wide track front suspension, Cortina front uprights with alloy hubs – long studs. carbon aerosceen. English axle in need of refurbishment. Some competition history prior to re-build £2850.00
Westfield SEi 1990 with a 1989 Chassis number. On SORN Matching chassis numbers front and rear anti roll bars, Full “Caged “with side impact bars Green tub with lightweight bonnet and nose cone with spare bonnet (high level ) High level areo screen . Floor mounted pedal box with bias brake and Hyd Clutch. Removable steering wheel, column and down link with quick rack. HD Drive Shafts, Disc brake rear upright Would make great road or track day car £3000.00
Neil on 01738 55005
Neil on 01738 55005
Should be the following John 01738 550005
