Who can make me a fuel tank for my tiger please?
jossey - 12/5/14 at 06:55 AM
Just need one with a hole for the sender unit and the output at the bottom for my bike engine...
Dj
[Edited on 12/5/14 by jossey]
femster87 - 12/5/14 at 07:24 AM
Mkengineering mate
CosKev3 - 12/5/14 at 07:29 AM
http://www.mkengineering.co.uk/?no_redirect=true#2231
Martin made a tank for Dug that's building the orange MK indy in the BEC section of forum, its spot on and very well priced
He will make it to your spec/drawings.
dhutch - 12/5/14 at 07:45 AM
Do tiger not supply a tank? or are you after a bit of a special?
PAUL FISHER - 12/5/14 at 08:50 AM
Another vote for Martin at MK Engineering, superb quality, at a good price.
jossey - 12/5/14 at 09:05 AM
Tiger do a tank but it has the fuel feed at the top which is causing a few issues for my bec.
I want one at the bottom to help fuel flow.
It's ok at the mo when the tank is full but while out at the weekend it starting running funny when the fuel level dropped low.
Plus the sender unit hole is a wierd size so I ain't using any fuel sender which ain't fun either lol.
Mile per gallon ain't easy to calculate without a speedo or fuel sender lol.
rdodger - 12/5/14 at 09:08 AM
Bryn at Allyfab did mine. Great Job.
JacksAvon - 12/5/14 at 09:25 AM
I just had one fitted by Tiger with a small sump in it at the bottom left corner and the fuel outlet from there.
Also fitted with a working fuel sender.
jossey - 12/5/14 at 11:33 AM
Thanks all.
jossey - 12/5/14 at 11:37 AM
Wasn't aware but thanks all compare quality and price with mk and tiger.
blakep82 - 12/5/14 at 04:16 PM
http://www.alloyracingfabrications.com/fuel-tanks/westfield.html
Theres a locost one there too, but if you ask him, he can make any changes needed
stevebubs - 12/5/14 at 04:25 PM
another vote for Bryn @ Allyfab..
zetec-phill - 12/5/14 at 06:38 PM
u2u
matty h - 12/5/14 at 06:49 PM
I use a chap at Normandy near Scunthorpe called Forge weldingfor all my ali and stainess welding made my brother a ai tank. Can send you details if intrested.
Matty
