hi as subject sugests im after some stone guards. wondered best place to get them ??thanks
richard
MAC1 sell carbon fibre looky likeys for £15 a pair.
DeDion do the real thing or just use c/f looky likey sticky back plastic, its sacrificial so tear off and renew when needed.
I got them from Robin hood, Stainless.
Steve.
[Edited on 24/6/06 by stevec]
Unless you are using a specific kit or style of mudguard, I would advise you make them. Piece of Kraft paper, two pieces of aluminium; at least that way you know they will fit.
I used 3mm rubber, bought it from a tool supply shop, matt black, cut to shape, and evo stick contact to fit.
No holes in the mud guards and if i need to change them its easy.
Only cost about £10 for 1m sq
I got mine from MNR - nice carbon effect and a decent size too. 20 quid if I remember correctly. Pre drilled - just fitted them with some black pop rivets!
ebay silver hand made £30 i got a set looks amazing
Item number: 320000772184
