Battery Cut Off Switch
Michael - 1/4/11 at 09:03 PM
I have brought a battery cut off switch with two keys.
Am i missing the point? I thought it must turn and lock inposition but i it is spring loaded and turns the key back to the inserted position and springing out.
Please advise.
flibble - 1/4/11 at 09:08 PM
Odd, mine turns and stays there, I'd say it's time to ask for a replacement!
Michael - 1/4/11 at 09:13 PM
I had wondered that but thought i best ask on here in case i get told its standard and i am stupid, i will though recheck the switch in case i have not turned it enough to lock.
carpmart - 1/4/11 at 09:28 PM
its circa 90 degrees to lock it!
Michael - 1/4/11 at 09:39 PM
Its now working.
I could see where it should lock but it was not getting that far due to a bit of plastic in the way.
A bit of brute force and it now locks at 91 degrees and stays locked.
Thanks to all.
