Flasher relay
chrisxr2 - 22/4/11 at 07:41 PM
no indicators at all, checked wiring, guessing relay has died.
wehrle
13 010 301
12v
pa6 6gf15
10r- 027024
googled it and not a sausage, anyone any tip or will any 12v 3 pin flasher relay do??
spiderman01980 - 22/4/11 at 08:06 PM
there should other numbers on there i.e 23wx2+3.4w, they are all different.
try this site http://www.aopec.com/new/en/products/?class_id=17
[Edited on 22-4-11 by spiderman01980]
snowy2 - 23/4/11 at 03:52 AM
if yours is a 3 pin relay then it is almost certain another 3 pin relay will work, (if you are using LED bulbs you may have problems) but if your using standard bulbs you'll be fine
Check the hazard switch as non working indicators can be often be traced to the switch not being fully in one position or the other!
[Edited on 23/4/11 by snowy2]
rusty nuts - 23/4/11 at 07:08 AM
If you are using Sierra column switches and have been caught in the rain the switches may well have got wet , try a squirt of contact cleaner around the hazard light section ,WD40 might work.
Michael - 23/4/11 at 08:01 PM
My indicators do not work if the Hazard switch is disconnected
(Mine is a seperate switch on the dash & indicators are on the stalk on column)
chrisxr2 - 23/4/11 at 08:31 PM
Thanks all, i believe i need an led one as my fron indicators are led, just stopped working, no water or anything anywhere near, tried putting hazards off and on few times but no dice.
