Feista Endura E starter problems
Bluemoon - 27/10/10 at 10:12 AM
Hi all,
Starter motor on our Festia (Endura E engine) has started to play up, spins but will not allways engage with the flyweel (complete with the nasty teeth on teeth noise)..
Replaced starter with a recon unit. Still does it.. Any ideas (will take the replacement starter back in case it's also faulty), is this a known issue?
Ta
Dan
marcjagman - 27/10/10 at 10:25 AM
Could be the ring gear that's damaged.
col - 27/10/10 at 05:27 PM
yep probably above or faulty battery connection.
