Hi,
Just going through the car, tarting it up a bit etc and would like to get hold of some of the above if anyone knows of a supplier?
I've had the usual inter web search but got fed up by page 10.
Looking for stuff like alternator brackets, the standard one is ridiculously heavy.
Light weight and pinto are not phrases that go together
From what I recall!
Burton Power do some bits, but I think you'll pay for them.
On the alternator bracket I made myself one from a piece of 50x50mm angle iron. Whilst not the lightest it was lighter (and smaller) than the
original item. It was also quick and easy to make as well.
Originally posted by Schrodinger
Light weight and pinto are not phrases that go together![]()
Again IIRC you can (if so inclined) buy an Aluminium cylinder block and head for a Pinto. You'll pay dearly for it and when compared to lighter weight engines not gain much out of it.
Fit a lightweight Denso type Alternator and a small Odysey (or similar) Battery and you will have saved a fair bit straight away
They don't call 'em The Anchor for nothing
The RS 2000 has an aluminium alternator bracket. There are also alloy bellhousings which must save quite a bit.
here you go eBay item number:252399120973
and if your feeling flush eBay item number:172215706049
[Edited on 23/5/16 by rash12]
Thanks all. All good ideas
I've seen the price of those blocks and heads. I don't understand why you would pay it personally.
I'd like to go ST170 but until then . . .
Suzuki, Honda and Yamaha do a comprehensive range of lightweight parts for the Pinto installation. Some of the unstressed parts are even supplied in magnesium. The above also fabricate superb lightweight sequential gearbox components, it's possible to even acquire a complete kit of engine/transmission parts, assembled as running unit. Have a browse.
Sorry, but couldn't resist that.
Joking apart, would it not be possible to fabricate brackets yourself - tube, top-hats and buckets are lighter than cast components. I'm assuming
you've looked at some of the lightweight bits from Burton, if they're any help in getting the weight down a bit.
http://www.burtonpower.com/alloy-ford-sohc-pinto-2-0-cylinder-head-ft850.html
