Where from? Need a non-standard length belt for my Zetec installation.
halfords
Originally posted by macspeedy
halfords
Look in your yellow pages for an industrial transmission and bearing supplier, they will be able to supply one to suit and will have experience of
measuring etc.
Paul.
Hi Steve
Fenner belts are made in Bury St Edmunds, Suffolk AFAIK
web site www.wyko.co.uk
HTH
Paul G
Hi,
Try a local motor factor.
I assume you are after a poly V type belt, if so the part no. will be for instance 6 PK 860, where 6 is the number of ribs and 860 the length in
millimetres.
Originally posted by davidwag
Hi,
I assume you are after a poly V type belt, if so the part no. will be for instance 6 PK 860, where 6 is the number of ribs and 860 the length in millimetres.
Ill second the Halfords suggestion.
I have been there a few times with non-standard installations and just rummaged through the fanbelt display looking for the right length.
They operate (or used to anyway) a similar part number system as described above for the belt length.
My local factors got all upset at having to actually do some work to find a belt rather than look it up in a book, so I just did the searching myself
in Halfords.
My local factors got all upset at having to actually do some work to find a belt rather than look it up in a book, so I just did the searching myself in Halfords.
mac lives a small blat from a supersized halfrauds........... that well known pedalbike shop that sell some car stuff as well. The laugh is you go
to partco to by the same stuff.
remember this from a while ago, some mentioned
"Falcon Automotive belt part code 6FR870 (870mm length)"
not sure what supplier but maybe worth a google. presume it also comes in different lengths.
hope this is of use
Originally posted by stevebubs
Ta. I'll try Camberley Autofactors tomorrow. May need to try 2 or 3 to make sure I get the right length
Steve,
That's where I got mine from- but then I was after a 'v'pulley so maybe that's easier to find.
Having failed with the string route (it goes too far into the groove) I just cut the Sierra pulley down to the right length then opened it up and measured it. Bought an FAI one to match.
HTH,
James
P.S. I work quite near the 'original' CAF if it helps and you want something picked up/sent.
My wife drives for a local parts supplier on Saturdays and sometimes delivers to Halfords . Always seems odd for a nationwide firm.
Why not use a belt that's slightly too large with a tensioner? It can't be hard to build a small wheel on a bearing on a dprung arm? ( I think the Mondeo v6 may have an arm you could rob)???
Steve,
Do you have no adjustability/tensioner on the alternator anyway? That 26mm difference between those two belts I'd have thought would be within
the range of the alternator pivoting on it's mount.
Or are you in danger of it hitting the 'Y' rails?
James
Just wrap masking tape around the pulleys as the belt would run, cut it off and measure it
