Author: Subject: Viento V8 Throttle
Irony
posted on 12/9/11 at 09:35 AM Reply With Quote
Viento V8 Throttle
Just setting up my throttle pedal and cable etc etc and I have a couple of questions
1. When attaching the cable to the pedal have you guys just drilled a tiny hole in the rod?
2. Any recommendations on where on the rod to drill. Higher up will involve more travel and lower down less travel.
3. I am hoping to put the return spring at the carb end. I am sure RPI et al will have something. Would I be advised to put a cable adjuster in or something in the system to enable fine tuning?
Cheers guys
K
scudderfish
posted on 12/9/11 at 11:19 AM Reply With Quote
1. My pedal has a tab welded to it, and the hole is in that.
2. It is also influenced by the attachment at the other end as well. Higher up will also give a lighter pedal with more precision. Mine has quite a long travel which means I'm less likely to be surprised by an excess of torque
3. Adjustment is pretty essential. Ideally your throttle pedal at rest should be roughly in line with your brake pedal pushed in. It makes heel & toe possible. You also want to have some sort of physical stop on the pedal so that when you push it as far as you can, you are not stretching the cable, which would eventually snap, but you do want to be at WOT.
Regards,
Dave
Irony
posted on 12/9/11 at 11:53 AM Reply With Quote
Sadly my Viento accelerator doesn't have a tab - just a rod.
I wish I could afford to buy everything for my RV8 from RPI. There stuff has always been brilliant. However it is also costly!!! The throttle cable kit is £40!!
scudderfish
posted on 12/9/11 at 12:01 PM Reply With Quote
I went to my local bike shop and got a brake cable for about £3. Throttle return springs were scrounged from local motor factors for a small amount i can't remember.
wicket
posted on 12/9/11 at 02:17 PM Reply With Quote
If it's the standard Luego throttle pedal where the rod is 1/4" dia (I think) then I created a ball end on the rod and used a standard Ford cable with the the female cup end with spring clip retainer.
Like this one
http://www.locostbuilders.co.uk/photos.php?action=edit&photo=Throttle_cables_7.jpg
http://www.burtonpower.com/1638310.html
but I did'nt pay £30 for it, came for my local motor factors.
jollygreengiant
posted on 12/9/11 at 04:52 PM Reply With Quote
I cut the cable attaching part off of the Granada (donor)) pedal and welded it onto the Luego item. JD
Paul (Notts)
posted on 12/9/11 at 06:56 PM Reply With Quote
Cable to throttle Ped
File the top flat and attach a clevis ( I think thats the correct name ) to the cable (pushes in and alen key locks it in place.)
attach as in pic.
I am using a bike brake cable cost £5 +another £4 for the clevis.
Paul
[Edited on 12/9/11 by Paul (Notts)]
