Author: Subject: Front Hubs viento
darrens
posted on 14/8/05 at 06:59 PM Reply With Quote
Front Hubs viento
I've just got round to fitting the front hubs, and there isn't enough of the bottom ball joint protruding through the hub to reach the top of the nyloc. I have used Maxi bottom ball joint as advised.
Has anyone else come across this problem or am I missing something
Darren
darrens
posted on 14/8/05 at 07:04 PM Reply With Quote
It's alright, I've used me loaf and realised they need to be drilled out to suit the maxi ball joints
Just havin a blonde moment.
Darren
Danozeman
posted on 15/8/05 at 08:27 AM Reply With Quote
LOL. I have them all the time. You are correct mate they do have to be machined!
Dan
wilkingj
posted on 26/8/05 at 07:20 PM Reply With Quote
Luego will do it for a very small consideration, and they have the jig to get the angles right etc... mine were a 15 min job to do them both... I didnt even get time to finish the coffee Should have taken then with you when you picked up the chassis..
Best Regards
Geoff
http://www.v8viento.co.uk
