Steve Lovelock
posted on 15/4/07 at 04:08 PM |
Velocity throttle pedal stop & return
Hello again,
I have fitted the throttle cable and realise that I need to make an arrangement for holding the pedal in the correct position.
Also I could do with a throttle stop. Is there a regular solution for this?
posted on 15/4/07 at 06:35 PM |
Drill the bulkhead and use a bolt with a nut each side of the bulkhead as a pedal stop
wilkingj
posted on 15/4/07 at 07:08 PM |
Drill the "L" shaped bracket and put a M10 or M12 bolt through for the pedal lever to rest on.
Throttle stop, just bend up a Large "U" shape, and attach it to the top of the "L" shaped bracket, and use an adjusting bolt
in the bottom of the "U" for fine adjustment.
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 16/4/07 at 07:23 PM |
Trouble with the stop at the top of the pedal it's possible to bend the pedal itself . With the stop at the bottom this can't happen.
