Neuronic
| posted on 10/3/11 at 10:37 PM |
Attempting to build a kit car..
Hey, I have long been a member of this forum and have never really been an active poster so here's to solving that problem! Secondly, I have
always wanted to build a locost however due to my age have never really had the money to do so before, until now (hopefully!) - and I am looking for a
bit of advice.
I am 18 years of age, and ever since I was given the opportunity to experience a seven on a track and being involved in a number of runs, not to
mention numerous amounts of kit car shows, I have had a burning desire to build one for myself.. one day.. and that I shall do!
Anyway, to cut to the chase, I am hoping to slowly build a Locost over a period of 2-3 years due to limited income from a full time job, not to
mention limited experience. I have considered building the chassis myself, however due to never having welded anything before I think it's safer
for me to buy one - at least then I know everything has been formed using jigs, that the welds remain neat and tidy and the steering geometry will be
correct.
My first question is this - taking insurance into consideration for what will be a 20 year old at the time.. as well as future-proofing - what would
be the best way to go about building the seven in terms of engine and donor vehicle? I was considering Mazda MX5 and the e36 as these have been
mentioned quite a lot throughout these forums as sierra based vehicles are becoming quite rare now, however I was wondering if there is anything else
I could *possibly* consider? I have also looked into Pinto engines and Zetec engines however I really cannot decide - the engine/donor needs to be
relatively cheap as previously mentioned.
Someone told me a while ago to use a 1.3 crossflow engine for insurance purposes and then later on switch to a Zetec engine using the same gearbox -
is this a good way to go?
I hope someone could shed some light on the situation and offer me some advice!
Regards,
Adam
[Edited on 10/3/11 by Neuronic]
wilkingj
| posted on 10/3/11 at 11:01 PM |
Welcome to the NutHouse!
Well Your age is against you insurance wise. So keep the engine size and power down to a minimum. If you can get a 1100 cc Escort crossflow engine its
about as gutless as you can get, and still leave your options open for later on.
ie with a Type 9 gearbox you can change up to a 1600 crossflow, or Pinto or later model. ie it gives you the most options for later on.
This way you keep your insurance costs to a minimum. Once you have a bit more age, and No Claims Bonus, you can change the engine for something a bit
more lively, without having to change your car. (You dont want to shell out on a IVA again!)
As for building, a lot will depend on your skill level. Cheapest is a scratch built chassis. However, you will need to be a reasonably good welder and
fabricator.
Check out something like a MK Indy or similar. This would give you a good chassis / body at a reasonable cost.
You dont have to shell out for all the bits in one go. Get a chassis and start there, and buy bits as you build. Thus you spread the costs over a
period of time.
Use the search facility as many common problems have been well covered in the past and are in the archives.
Dont be afraid to ask... there are a good bunch of knowlegeable people on here.
If you dont get an answer within 24 hrs, then the problem is probably a bit more difficult that you first thought
Finally... Hope you have a good sense of humour... you will find it useful!
Good Luck.
Best Regards
Geoff
http://www.v8viento.co.uk
indykid
| posted on 10/3/11 at 11:02 PM |
A number of years back....seven to be precise, I was in your position and built a 1.6 pinto engined indy.
If I were in the same position now, I'd use a post '91, pre '94 1.6 mx5. Insurance will sting for the first few years, but at 20, I
think I'd got through the worst of the premiums, including crashing it 5 months after I got it on the road, so that weighted premiums til I was
22ish.
My advice....when you think about taking it out for that last run out in november......don't.
Apart from that, scour the usual places for a cheap mx5 and get cracking. I've got one as a daily driver and I think it'd make an ideal
engine for a 7. It loves having its neck wrung
Tom
Miks15
| posted on 10/3/11 at 11:09 PM |
Hey Adam,
I am very much in the same posisiton. I have been building since i was 17 (now 19) and used a 1.6 E36 as a donor. I scratch built a chassis based
loosely on the book and the haynes book. Im nearing the end but with being at uni i dont get much time to work on it.
On a seperate note my bro lives in deeping so when you get a bit further a long id love to come down and see your car and possibly lend a hand if ever
you need it when im in the area.
Mikkel
Neuronic
| posted on 10/3/11 at 11:10 PM |
Thanks for the replies - yes I was looking at mx5's, just wasn't sure about the insurance on them.. I take it you mean a 1.6 engine?
Neuronic
| posted on 10/3/11 at 11:11 PM |
quote: Originally posted by Miks15
Hey Adam,
Mikkel
Thanks Miks! That's very kind of you! I am in the same situation as I work full time and do a part-time degree at uni.. It's just
something I would love to do! How far are you with your build?
Steve Hignett
| posted on 10/3/11 at 11:12 PM |
Just a quicky answer for now, but it should be a step in the right direction:
I assume you are building to a budget, or at least that's the plan. So why don't you add an arbitrary amount to everything you buy,
let's say £10, so an engine that would cost you £50 costs £60 and a set of shocks for £100, £110 and so on. You put all those £10's or
£20's etc into a pot and that's what you use for your insurance. Obviously you could do a similar thing with a DD each month to a
parent's account; £20 pm for 3 years would be over £700, that shouldn't be far off the insurance for something in the smaller engine
range, but not as low as a 1.1 etc...
In accordance with the advice above, go for something in the 1.6 range, maybe even a 1.4 K series engine or a 1.4 duratec (or whatever that yamaha
engine is in the ford puma)? Build the car with light weight in mind and you'll be very surprised by how quick it is...
Or go for a smaller bike engine say a GSXR 750, and go for ultimate lightweight... Get a pre-Lit westy or very early caterham and strip it down and do
a nut and bolt rebuild...
[Edited on 10/3/11 by Steve Hignett]
Neuronic
| posted on 10/3/11 at 11:15 PM |
Thanks for that - that's a good idea. Funilly enough I was also considering K-Series engines as they are very light, provide good bhp, are revvy
and low maintenance engines however they are FWD arent they? However the benefit is that they are cheap!
I know that some Caterhams used them but how did they convert them to RWD?
ali f27
| posted on 10/3/11 at 11:44 PM |
Hi cheapest way is to use ford rear end type 9 box and 1300 ford engine and upgrade as birthdays allow ins wise
you can go 1.6 cvh or pinto bolt engine straight in 1.8 cvh or pinto straight in 2.0 pinto or 2.0-2.3 i4 twin cam ford (rs 2000) or cosworth straight
in no back end or geabox change no piont in zetec no lighter than pinto similar power then change bellhousing and go duratec.
Good luck keep going Ali
Neuronic
| posted on 10/3/11 at 11:48 PM |
Thanks for that - by 1300 ford engine do you mean xflow?
skydivepaul
| posted on 10/3/11 at 11:56 PM |
the k series engine is usually found in FWD cars. with the right bellhousing and transmission they can be fitted to a RWD car as per caterham
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
ali f27
| posted on 10/3/11 at 11:57 PM |
Yes 1300 crossflow find out how much 1600 or 1800 pinto would cost to ins cheaper to buy than 1300 would need to lean to weld first dont learn on your
chassis buy haynes roadster chassis seirra back end future proof yourself
We have built 4 cars an f27, haynes with 2.3 rs engine and 4 wheel drive, mk with fireblade, and haynes with 300 bhp duratec hillclimber
ali f27
| posted on 11/3/11 at 12:00 AM |
Nothing wrong with k engine would just need to add bellhousing to budget every thing else woul be the same
ali f27
| posted on 11/3/11 at 12:02 AM |
start looking for 4x4 seirra back end lsd discs etc never need to upgrade what ever the power
Neuronic
| posted on 11/3/11 at 12:04 AM |
Right, well thanks to everyone who has replied.. I have now been given a wide range of ideas! And about 4-5 different engine ideas!
Which one do I use haha - my lack of knowledge really doesn't help me limit the choices! K-Series is looking promising though.. as they are
*relatively* new, cheap and produce good bhp.. Anyone strongly advise differently?
[Edited on 11/3/11 by Neuronic]
Yazza54
| posted on 11/3/11 at 12:05 AM |
Don't muck about with an ancient, gutless, heavy 1.3 xflow.
For simplicity and cheap insurance you want a early carbed blade engine. Simples, cheap and so so effective.
I'm unhappy cos I eat and I eat cos I'm unhappy
Neuronic
| posted on 11/3/11 at 12:08 AM |
Aren't they relatively expensive?
SeanStone
| posted on 11/3/11 at 12:17 AM |
Would a bike engine not give you more performance than a lower litre road engine and also reduce your insurance premium?
Yazza54
To insure? No. I could insure two R1 fisher furys for what it'd cost me to insure a fiat punto. The one r1 fury will do though. I'm 20
btw.
The engines are cheap, light, easy to move around and work on, clutches take 30 mins to fit. Will transform a quick car into a fast car. These engines
are built to take abuse and tbh if my r1 went pop torrow I'd have another one in by the end of the weekend for not a lot of money. Though
I'm confident that wont be happening.
People also forget that with such small wheels and low speed gearing in comparison with a bike you're not putting as much stress on the box as
you may think. Though balls out standing starts will kill any gearbox eventually. More bike gearbox damage comes from poor shifting or pneumatic
shifters.
I seriously wouldn't consider a flow or pinto. You're a young lad, you'll love the drama of a BEC.
[Edited on 11/3/11 by Yazza54]
Yazza54
| posted on 11/3/11 at 12:19 AM |
Yep. Ideal.
Easy install too with an earlier carb engine (still nowhere near as early as a xflow!!)
norfolkluego
| posted on 11/3/11 at 12:31 AM |
btw.
shifters.
Haven't insurance companies cottoned on to bike engines then, do they just rate on the capacity?
eddie99
| posted on 11/3/11 at 02:15 AM |
Hi mate,
Im 18 now... Been building since i was 16 i guess.... Have a kitcar pretty close to IVA but its on the back burner as getting into racing at the
moment.... Don't try bike engine, Insurance companies have caught on... I'd say the 1.6 MX5 engine is what you want to be putting in, you
can turbo it up to 200bhp cheap as well ... I've got a 1.8 blacktop zetec, kind of hoping to IVA it and be able to use it a bit this summer...
Your not to far away in Peterborough, im at uni in coventry and home in essex so if im ever in the area
Regards
Ed
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
Yazza54
| posted on 11/3/11 at 06:52 AM |
I'm paying a good 700 quid less for my R1 fisher fury than I was for my 1.8vvc GTM libra...
That's with a hefty mileage still on the policy because I'm going to put 3500 miles on it in 10 days in the alps this year. £9k value..
Neuronic
| posted on 11/3/11 at 08:50 AM |
I would also like to know this, will kind of determine whether I go BEC or Road Engine I guess
Yazza54
| posted on 11/3/11 at 09:06 AM |
Have I not just made it pretty clear?
