Kit Contents
Hi Rich, i have emailed this to you, however here it is again. I trust this will help, if you aor any one else needs any further assistance please do
not hesitate contacting us on 01733 552911.
Best Regards The Luego Team.
Velocity & Viento Comp List Of Parts
1) Professionally Welded Chassis, Stress Analysed By Cranfield University
“Come and see the quality for yourself”
Powder Coated (Any Colour)
Chassis (box-section spaceframe with suspension mounting brackets, brake pipe brackets front & rear, hand brake brackets, roll bar with back stays
fitted (not bolted), 4 point harness bar, steel floor fitted, rad brackets, steering brackets, bulk heads, petrol tank bracket, steering column
bracket,)
(2) Suspension/Steering
Conversion Boss x 2, Top W/bones x 2, Bottom W/bones x2, Rear Top W/bones x 2, Rear Bottom W/bones x2, Rear Camber Adjusters x 2, Rear Hub Carriers x
2, Poly Bush with inserts Set, Nut x 2, Adjustable dampers 12” x 2, Adjustable dampers 12” x 2, 8" rear springs 180 lbs x 2, 8" front
springs 300 lbs x 2, Top ball joint and nut x 2, Bottom ball joint x 2, Steering rack, Rack Extensions, Track rod ends and nut x 2, Steering Column
Fitting Kit, Steering Rack Brackets & Rubbers.
(3) Bodywork (Various Gel Coat Colours)
Nose x 1, Scuttle x 1, Rear Wings x 2, Cycle wings x 2, Bonnet x 1, Rear Panel x 1, Dash x 1 , Inner body finishers x 2, Alloy Full Length side &
internal panel set, cut to size, folded with holes for W/bones,
(4) Brakes
Goodridge Velocity Braided hose set, Brake light switch x 1, Brake warning lamp x 1, Hand brake cable x 2, Standard Pedal Box,
(5) Luxury Light Package
Black head lamps with side lights x 2, Indicator rubber stalks front x 2, Indicator repeaters x 2, Number plate lamp x 1, Rear lamp cluster x 2, Rear
fog lamp x 1, Reversing Light,
(6) Clocks High Quality (ETB)
Speedo (high quality) x 1, Tacho (high quality) x 1, W/Temp (high quality) x 1, Oil Pressure (high quality) x 1, Volt Meter (high quality) x 1, Fuel
Gauge (high quality) x 1, Fuel sender unit x 1 (high quality), Adaptors,
(7) Windscreen
Windscreen (laminated) with Frame x 1, Alloy windscreen supports x 2, Windscreen bolts x 6,
(8) Interior
Wing mirror x 2, 4 Point Harness x 2, Premium High Back Cobra Seat x 2, Seat Runners,
(9) Engine parts
Engine mounts (steel) x 2, Engine mounts (rubber) x 2,
10) Miscellaneous
Alloy rivet pack 4mm x 12mm 200 off, Front wing support/stay x 2, Wiring loom with Fuse Box (new) x 1, Relay Pack x 1, Petrol tank 6 gallon x 1,
Petrol tank straps x 2, Diff Bolts x 2, Luego nose badge, Grille,
