andyd
posted on 15/8/03 at 09:28 PM |
Grant a question for you!
Grant,
Another thread on this forum has pointed out the dangers of using rivnuts to secure the brake master cylinders to the pedal box (see
http://forum.locostbuilders.co.uk/xmb/viewthread.php?tid=4905 from page two onward)
Can you please let us have your "company line" on this matter as I believe you too use the same fixings as that shown in the original
posters picture.
[Edited on 15/8/2003 by andyd]
ChrisW
posted on 16/8/03 at 02:13 PM |
Mine didn't come with fastenings of any kind - had to drill and bolt the pedals in myself
Chris
My gaff my rules
wicket
posted on 16/8/03 at 05:08 PM |
Mine came with the Ø38mm m/c hole + 2 off Ø10mm fixing holes, no threaded bushes.
andyd
posted on 16/8/03 at 07:44 PM |
Maybe ours was a "special"
It came with gold coloured 8mm rivnuts. To play on the safe side we are going to use longer bolts for the m/c's and then put a lock nut on the
pedal box side. That should hold it all in place and not put any strain on the rivnut threads.
ChrisW
posted on 17/8/03 at 08:55 PM |
I was excluding the holes for the master cylinders - mine had those too!
Chris
My gaff my rules
andyd
posted on 18/8/03 at 11:46 AM |
Had a closer look at the fasteners on our pedal box on Saturday and they are definately a rivnut varient. They look brass but I doubt that they are.
They were definately fitted by Luego as we've not touch that part at all, yet!
Luego Sports Cars
posted on 21/8/03 at 04:57 PM |
Pedal box
Hi guys. The rivnuts are fine as long as you use a spring washer to lock the boly off. If you are worried do as andyd has.
Best wishes and enjoy your builds, The Luego Team.
