<<  1    2  >>
Author: Subject: Pre-sva pics - 1 week left, opinions please
posted on 31/1/09 at 07:51 PM Reply With Quote
As Geoff has already suggested front wings are too short,some of your edge trim may not be seen as "permanant"
2
jacko
Originally posted by DanP
Originally posted by jacko
I see your seat belts go round your seats is this ok for the sva with them rubbing on the seat edge?
why have you done this and not gone though the holes in the seat ?
I thought this was fairly common for sva - avoids them pulling on the harness holes under tension, is it not then?
Hi Dan i don't know but it would be a shame if it failed for that
your car look very nice and good luck with the test
DanP
posted on 31/1/09 at 07:54 PM Reply With Quote
I will try running them through the slots and see what i get.
Thanks, thats kind of you to say.
Dan
adithorp
posted on 31/1/09 at 08:10 PM Reply With Quote
If you put the belt through the hole then the mount has to be higher than the bottom edge of the hole. They checked mine with a spirit level. Your look ok from the pictures.
Do the seat belt mounting captives go right through to the other side of the tube? They won't pass if they're just welded to the top face.
adrian
http://jpsc.org.uk/forum/
mistergrumpy
posted on 31/1/09 at 08:22 PM Reply With Quote
Nah you'll be right with the belts round the seats. A few on here have done the same. Myself included as I have Intratrim Odyssey's and they were not commented on.
lsdweb
posted on 31/1/09 at 08:44 PM Reply With Quote
I can't comment on the 'SVAable' items but it looks good! Well done!
ReMan
posted on 31/1/09 at 11:31 PM Reply With Quote
IMHO the issue with the front wings is NOT that they are above the centreline, I dont think that matters.
BUT they are not Ahead of the wheel rim in plan view and that does.....
NeilP
posted on 1/2/09 at 04:23 PM Reply With Quote
Cracking looking car Dan - the only SVA things I could spot have been flagged.
Best of luck with it!
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
Paul (Notts)
posted on 1/2/09 at 07:39 PM Reply With Quote
Good luck Dan...
wilkingj
posted on 3/2/09 at 09:16 AM Reply With Quote
I think that if the belts go through the holes in the seats, and they touch the hole sides (more like the top / bottom of the hole) when wearing the belts, ie they put pressure on the seat. Then the Seats have to be certificated to say they can take the strain.
This is why people leave the belts outside the holes, as the Cobra seats dont have the correct certification. (I am 95% sure this is the reasoning).
I set the height of the seat so they went straight thru the holes when being worn, and had no problem at SVA and I have Cobra 7 seats as well.
Best Regards
Geoff
http://www.v8viento.co.uk
<<  1    2  >>
