<<  1    2  >>
Author: Subject: Attempting to build a kit car..
Neuronic
posted on 11/3/11 at 10:35 AM Reply With Quote
Originally posted by Yazza54
Originally posted by Neuronic
Originally posted by norfolkluego
Haven't insurance companies cottoned on to bike engines then, do they just rate on the capacity?
I would also like to know this, will kind of determine whether I go BEC or Road Engine I guess
[Edited on 11/3/11 by Neuronic]
Have I not just made it pretty clear?
Oh sorry, I have only just seen your post! Thanks for that information Yazza. What complications am I likely to run into with going bike engined as I would need to dry sump wouldn't I, and from what I hear that can be expensive? I have absolutely no experience with bike engines at all.
Yazza54
posted on 11/3/11 at 10:41 AM Reply With Quote
R1 or blade just need a sump baffle plate. Easy and cheap.
Busas need dry sump.
I'm unhappy cos I eat and I eat cos I'm unhappy
Neuronic
posted on 11/3/11 at 10:45 AM Reply With Quote
Oh I see.. sounds easy enough, is there anthing else I should know/be aware of regarding BEC? Appreciate the help Yazza.
Yazza54
posted on 11/3/11 at 10:53 AM Reply With Quote
Well there's the obvious lack of reverse but a bit of forethought usually solves that. You could always fit an electric one though.
Look into what diff ratio is best for your gearset too, easiest to just copy what someone else already uses. Mine runs a freelander diff as it gives a higher top speed and is lighter than sierra. Or you could go live axle..
Bike engines are relatively simple, after all you don't have the room for masses of wiring and clutter on a bike!
UncleFista
posted on 11/3/11 at 11:14 AM Reply With Quote
Another plus on a crossflow (or other engine of that age) is that you only need to meet the "visible smoke" test on the IVA and forever afterwards.
What I mean is, if you pass the test with an old engine, then the car will only ever have to meet those standards, whatever engine you change to in the future. Much simplifying the MOT.
Tony Bond / UncleFista
Neuronic
posted on 11/3/11 at 11:20 AM Reply With Quote
That is very interesting to know UncleFista! I will take that into consideration. However from taking a quick look around - it seems crossflow engines are quite expensive now, from what I can see.. however I still need to perform a more in-depth search
Yazza54
posted on 11/3/11 at 11:37 AM Reply With Quote
I'm sorry but if you can build a car you can build a IVA/MOT friendly exhaust to slip on as and when.
Build the car you want to end up with for the long term, not based on the odd test once a year and the initial IVA.
Neuronic
posted on 11/3/11 at 11:50 AM Reply With Quote
I see your point Yazza, a quick question for you - where did you pick up your R1 engine.. from performing a quick search for blade engines they seem to be quite pricey.
stupid3ish
posted on 11/3/11 at 11:54 AM Reply With Quote
Hi guys,
I'm just about to start the same sort of project, and have the same sort of background,been to shows. Now since starting a job I've decided to start a build.
I've been debating over an mx5 build or BEC.
Since bec has been told as lower insurance. I was wondering about the price of a bike engine. Ask I can seem to find is like R1 engines for close to 1k. Is that the normal sort of price? Are there any cheaper places to look other than ebay?
Michael
Yazza54
posted on 11/3/11 at 12:05 PM Reply With Quote
I built my libra but not the fury. However if I did another I'd be going the same route or poss a zx14.
It was brand new at time of build for £2k but I've seen plenty of 5jjs and 893/919 etc blades on eBay and such for around 500 quid.
Sometimes worth looking for full bikes aswell. Seen people remove the engine and sell on the frame before.
I just typed 'fireblade engine' into eBay and voila! Cheap motors.
I can't link them cause I'm on my iPhone but have a look..
Yazza54
posted on 11/3/11 at 12:12 PM Reply With Quote
There's always the zx9 engine too, kinda in-between the r1 and blade on power. But people do tend to favour the r1 and fireblade for litre bike engines. Not sure why.
Theyre the two I'd consider. Blackbird needs dry sump and has a weak box so they're your best bets.
JimSpencer
posted on 11/3/11 at 12:21 PM Reply With Quote
Hi
First off don't forget you'll need reverse gear to pass the IVA test when doing a BEC build, so do factor that in.
Now as a different idea;-
Why not save up for a short while and go shopping for a tatty but road legal 'seven' of roughly the type and finish you want.
Doesn't really matter what engine/box (as long as it's not too weird!) as think of it as a collection of components, that cost less in a lump than they would do seperatly, that doesn't need an IVA test..
SORN It.
Strip it right back to a bare chassis and start again - you now have a 'comprehensive kit' really!
If you decide to change the engine / colour write to the DVLA and let then know.
Once completed MOT it and drive off into the sunset.
There are lots of plusses to this method starting with not having to worry about a donor car (and the fun one can have with neighbours / parents / wifes while dismantling one of them) carrying onto;-
if it's been built and you strip it you can see how it's been done, fix what you don't like and do a propper job when putting it back together.
You won't end up with a huge pile of kit you don't eventually use..
It's cheaper.
Neuronic
posted on 11/3/11 at 02:26 PM Reply With Quote
Originally posted by eddie99
Hi mate,
Im 18 now... Been building since i was 16 i guess.... Have a kitcar pretty close to IVA but its on the back burner as getting into racing at the moment.... Don't try bike engine, Insurance companies have caught on... I'd say the 1.6 MX5 engine is what you want to be putting in, you can turbo it up to 200bhp cheap as well ... I've got a 1.8 blacktop zetec, kind of hoping to IVA it and be able to use it a bit this summer... Your not to far away in Peterborough, im at uni in coventry and home in essex so if im ever in the area
Regards
Ed
Hey mate, good going! Just had a quick look and those engines are so cheap! Might consider it! Do you know what the insurance is likely to be for you at 18?
Mr Whippy
posted on 11/3/11 at 03:48 PM Reply With Quote
Insurance for kit cars tends to be a lot cheaper than production cars. A friend who had a drink driving ban at the age of 22 found the only thing he could afford to insure was a VW based Nova for around £600, his crappy rusty old Fiesta was £1400 for just third party
stupid3ish
posted on 11/3/11 at 04:48 PM Reply With Quote
I see your point Yazza, pretty cheap. What sort of mileage would you guys look for in a bike engine?
Neuronic
posted on 11/3/11 at 04:50 PM Reply With Quote
I read somewhere that most bikes won't last more than around 75k miles - correct me if I am wrong.. It was just something I read.
wilkingj
posted on 11/3/11 at 06:21 PM Reply With Quote
Well maybe, but in general, its highly unlikely that you will be doing 10K miles a year in your kit car.
In 4 years I have done barely 7k miles.
I have limited mileage insurance which helps keep the costs down as well.
Best Regards
Geoff
http://www.v8viento.co.uk
UncleFista
posted on 11/3/11 at 06:58 PM Reply With Quote
What exhaust would you recommend for my post '96 zetec on bike carbs to pass post '96 emissions ?
I'm not saying it's worth building a car with a crossflow for only that reason, but if insurance and cost is a major factor the emissions bit just adds another plus point
Miks15
posted on 13/3/11 at 08:02 PM Reply With Quote
Originally posted by Miks15
Hey Adam,
I am very much in the same posisiton. I have been building since i was 17 (now 19) and used a 1.6 E36 as a donor. I scratch built a chassis based loosely on the book and the haynes book. Im nearing the end but with being at uni i dont get much time to work on it.
On a seperate note my bro lives in deeping so when you get a bit further a long id love to come down and see your car and possibly lend a hand if ever you need it when im in the area.
Mikkel
Thanks Miks! That's very kind of you! I am in the same situation as I work full time and do a part-time degree at uni.. It's just something I would love to do! How far are you with your build?
Well most of it is together, just a matter of finishing bodywork off and then all the IVA bits really, just a pain being away from home so much of the time. but hopefully get it on the road this summer (fingers crossed!)
Irony
posted on 21/3/11 at 01:19 PM Reply With Quote
Originally posted by JimSpencer
Hi
SORN It.
It's cheaper.
I am half way through my build and if I was starting over (older, wiser etc) I would do as above. I feel this is now the cheapest way to build a kit car. I have found that things like the 'engine' etc are only a part of the cost. With buying a fully built kitcar and then stripping it down you have every bit already.
<<  1    2  >>
