Paul (Notts)
| posted on 29/5/07 at 09:17 PM |
Lots of problems to solve ahead of you but it will be worth it in the end.
In the next year or so we should be able to organise a convoy of 10 - 15 Viento's to one of the shows.....
That will produce a big CO2 footprint!!!!!!!!!
Paul
bj928
| posted on 29/5/07 at 09:30 PM |
quote: Originally posted by goodall
what kind of transmission would you be thinking of using to get awd? something out of a 4x4 could work since weight isnt that much of an issue if your
edging on 1000bhp
best to keep it a bit simpler for the moment i guess as im sure its going to be
hard as it is to get it all to work with out complicating it with extra driveshafts and stuff
the 6 speed R34 skyline box is a getrag, and i think its the same make as the dodge pickup 4x4, so they may do a bellhousing that would alow fitting.
goodall
| posted on 29/5/07 at 10:51 PM |
fitting.
that would be a good place to also get the drivetrain as well then, but maybe the ratios arnt as good as those you can get with the the mustang
diff
ah so you have considered the option and even done some research , thats good to see
have to keep a eye open on your build and any of your future builds cause as it sounds very interesting
bj928
| posted on 30/5/07 at 11:53 AM |
fitting.
diff
it took longer to sort the money out for this project than i first thought, so i spent the time on the internet doing research, as its such a major
project i wanted to make sure i new as much as i could, i spent ages researching the ford modular v8 as well, plan on building something mental with
one of them at some tme with twin turbos..
..::Nightfire::..
| posted on 30/5/07 at 12:48 PM |
quote: Originally posted by Paul (Notts)we should be able to organise a convoy of 10 - 15 Viento's to one of the shows.....
Not too bad once you offset the carbon saved from driving a car made from recycled parts and not in a korean factory out of plastics and fabrics from
the 4 corners of the earth.
P::..
mark-wiring
| posted on 30/5/07 at 04:37 PM |
Tonights quick update
http://www.v10viento.co.uk
Have to recommend
http://www.extraefi.co.uk/
For all Megasquirt needs
Simon
| posted on 30/5/07 at 06:52 PM |
Heeeeey (in the voice of Zaphod Beeblebrox), it's nearly finished
Nice big workshop. Almost as if you could walk round the car
Simon
bj928
| posted on 30/5/07 at 08:32 PM |
the workshop is 40' X 40', is next doors though, just sold my place with 2 double garages at the bottom of garden, thats whats financing
the build, the workshop is nice, but the veiw is even better.
[Edited on 30/5/07 by bj928]
mark-wiring
| posted on 31/5/07 at 11:19 AM |
Oh sod the view unless you include the supercharged jet ski and the ramp at the bottom of the garden to get into the sea lol
New hubs should arrive today and should also have quick adjust top mounts for camber i hope pics later
Have to recommend
bj928
| posted on 31/5/07 at 06:34 PM |
was talking to the owner of rally design today and from what i can tell, the front sierra hubs are a "make do", the setup seems to be
originaly designed for cortina uprights, but when i asked bens brother if i could use cortina uprights he said no, the question is, if i can't
why, or can i.
NeilP
| posted on 31/5/07 at 06:41 PM |
Que? The viento wishbones are designed for sierra bits - s'what most of us have used and they all work....
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
bj928
should be getting access to a set of these to try after newark,
http://www.wilwood.com/Products/010-spindles/001-pinto/index.asp
and a set of 6 pot wilwood 6 pots + 330mm discs
NeilP
| posted on 1/6/07 at 10:26 PM |
BJ,
330mm might not be enough - See if you can find one of these that he's towing in a scrapper
  big brake
