Author: Subject: wheres the clutch
Volvorsport
posted on 26/12/08 at 01:30 PM Reply With Quote
wheres the clutch
http://cgi.ebay.co.uk/LOOK-GENUINE-BMW-K1100LT-K1100-K-1100-LT-GEARBOX-ASSY_W0QQitemZ190272884288QQihZ009QQcategoryZ76120QQssPageNameZWDVWQQrdZ1QQcmdZ ViewItem
i believe thats the canted over flat straight 4 , not the boxer engine .
wheres the clutch ? is it inside that cover ?
i know nothing about bikes !!
www.dbsmotorsport.co.uk
getting dirty under a bus
zzr1100rick2
posted on 26/12/08 at 03:39 PM Reply With Quote
yes it is flat 4 and the clutch bolts on the flywheel one the end of the crank same as most cars as it was originaly a car type engine
stevec
posted on 26/12/08 at 03:42 PM Reply With Quote
Clutch looks like a car one bolted to the back of the crank.
See Picture
Steve.
mad-butcher
posted on 26/12/08 at 07:03 PM Reply With Quote
beautifully engineered clutch,
Volvorsport
posted on 26/12/08 at 07:11 PM Reply With Quote
so a shaft drive 1100 , looks like a good donor ?
niceperson709
posted on 26/12/08 at 11:54 PM Reply With Quote
Just check the rotation direction of the drive shaft output and remember that the drive shaft is not central to the crankshaft.
Grinnal scorpions use this engine and they get along quite nicely
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
