Author: Subject: Velocity rear lights
Cubby
posted on 30/12/08 at 01:34 PM Reply With Quote
Hi guys,
Bit confused over fitting the rear lights.
Have people fitted them flush or surface mounted?
Flush mounted looks a bit tight on clearance between back of light cluster and tyre. Rescued attachment Rear Lights.jpg
piddy
posted on 30/12/08 at 04:22 PM Reply With Quote
Hi. I've just taken a look through my Luego pictures and found five different cars with these lights fitted and they are all fitted flush.
tomgregory2000
posted on 30/12/08 at 04:23 PM Reply With Quote
ive flush fitted mine on my viento
Cubby
posted on 30/12/08 at 04:36 PM Reply With Quote
Thanks guys.
Yeah thought as much but just thought I'll check.
Dave Bailey
posted on 30/12/08 at 05:52 PM Reply With Quote
If they are flush is there not a problem with the visibility? I though for SVA that the lights need to be upright as near as possible. I haven't mounted mine yet and would prefer to mout them straight to the arch...
Dave B
piddy
posted on 30/12/08 at 07:40 PM Reply With Quote
They should be ok mounted flush. It's only the fog light that needs to be Parallel to the ground.
