DanP
posted on 9/2/09 at 02:03 PM |
good SVA fail at southampton
Just got back to Portsmouth now from Southampton, have driven a total of 50 miles in windscreenless, roofless car in some of the wettest weather
we've had all year, I think i'm as wet and cold as I've ever been but I've been grinning all the way!
Had a really nice pair of testers, whole thing was a totally pleasant affair, no problems with the interior and only 2 on the exterior, fails points
were:
No spring washer on front caliper bolts
Speedo was not playing ball (reed switch was bouncing so it was counting too many pulses),
Radius on harness mount bosses at the bottom
Need some oversize washers on the steering rack
Bias bar wasn't quite pinned to their liking
Bootlid needs a retaing catch (I had taken the lock out for the radius test!)
Engine was running quite rich so failed the emissions despite being tested on 1979 standards!
Some trim needed adding on exhaust cut out
Headlight brackets wobbled so need a better clamp
wilkingj
posted on 9/2/09 at 02:08 PM |
Well thats not too bad a fail.
All do-able.
Its a bit of a b*gger in a Se7en when its inclement weather.
Been caught in a cloudburst up the A1 going to the Newark show (in summer) a couple of years ago. Its not nice!.
Let alone with near freezing conditions.
I take my hat off to you and bow lowly infront of you!
Well done... It should pass next time. Just take care to get it all spot on. Especially the emissions.
Best Regards
Geoff
http://www.v8viento.co.uk
DanP
posted on 9/2/09 at 02:19 PM |
Thanks Geoff, I think the emissions should be solved when set the timing right., hopefully! The rest i'm gonna start tackling once I've
warmed up sufficiently!
tomgregory2000
posted on 9/2/09 at 02:20 PM |
Well done Dan
Thats not bad at all is it.
Ive got mine booked in on the 11th march, i take it the front wheel arches were ok then?
Would it be possible for you to come and have a look over my car at some point to see what i need to do/cover for the test? i would cover the costs
Tommy
pewe
posted on 9/2/09 at 02:26 PM |
Nice one - counts as a good fail.
Braver man than I driving it there.
I got over the ex. cut out radius (one of Marc's favourites) by buying some ali. tube from B&Q cutting a seam out of it then cutting across
the diameter every 20mm or so then bending and sticking it on with exhaust paste.
Good luck with the re-test.
Cheers, Pewe
DanP
posted on 9/2/09 at 02:32 PM |
Cheers Tommy,
I made up some extensions for the front out of a wheel arch liner I got from a scrappy, the back didn't need anything but it wouldve been useful
to keep the spray off me.
Deffo make sure your battery is upto the job as you will have to start your car up a lot.
I'm not exactly an expert but I'll gladly nip over to give you a hand one Saturday if you like, just let me know when's good and
I'll check when I can make it.
Dan
wilkingj
posted on 9/2/09 at 02:39 PM |
quote: Originally posted by DanP
Cheers Tommy,
Dan
Now you understand why the guards need to be so low. I have yet to take my oil can extensions off. I really must make some new ones so they look
better.
no problems without a windscreen. Just get a full face helmet and some bike gear. Thats what I did.
I wne to the BMF Bike show - Frank Thomas Reject tent - Got it all for under £100, and it was all new kit as well.
Best Regards
Geoff
Glad your happy about that fail. Bit puzzled over the spring washer on the calipers though. OEM's don't have em and I didn't have
them on mine....
[Edited on 9/2/09 by coozer]
DanP
posted on 9/2/09 at 03:14 PM |
the bolts have to be shakeproof either with locktite or spring washers apparently.
Dan
posted on 9/2/09 at 03:21 PM |
Sounds like an easily resolved list
Had my SVA test & retest at Southampton with a tester called Mark - top bloke, very good at explaining exactly what he was looking for and what
would be acceptable on the fail points. I had a similar niggle list including headlamp aim which he even helped me set correctly with the test
equipment.
Good luck with the retest - hopefully you'll get a dry day next time
posted on 9/2/09 at 04:00 PM |
them on mine....
cortina uprights used lock tabs.
Danozeman
posted on 9/2/09 at 04:35 PM |
Not a bad fail mate. i too am confued about the caliper bolts. Mine have nothing and he didnt question it. You should have said there was locktite
on them.
Dan
jollygreengiant
posted on 9/2/09 at 04:42 PM |
Dan
Congrats, 'I think' on the fail, not a lot there. However, the only bit that confuses me is the caliper bolts, yes I know the reason, but
the standard original bolts aren't long enough to take washer's and how are they going to know about thread lock unless they/you undo
them, and, does that/that does also apply to the caliper pins.
Just starting to fill out (& send off my mid to end off week) my application, now I have money in the bank again.
NeilP
posted on 9/2/09 at 10:27 PM |
Well done Dan - Only a few minors to resolve and you are on the road I predict...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
posted on 10/2/09 at 07:18 PM |
Well done Dan, I was with Geoff on the A1 to Newark and know whats it's like in a monsoon. Give your column switches a squirt of WD40 , both
Geoff and I have had problems with them after the soaking we had.
