kenton
| posted on 20/3/09 at 06:26 PM |
luego suspension bushes
Hi all,
had my first track day at brands yesterday, great fun! The only pboblem is i how have play in the nearside rear wishbone joints. All those right hand
corners!!
Are there any better quality plastic inserts available off the shelf from eg rally design?
thanks kenton
Paul (Notts)
| posted on 20/3/09 at 06:53 PM |
If you have not dealt with the crush tube size issue ...
this will cause in and out play on the rear wishbones. if this is the symptom then its probably due to the bushes needing trimming a bit and the bolt
sleaving in the crush tube.
Paul.
The bushes are very tough and should not produce any play.
Just my thoughts.
| posted on 20/3/09 at 07:15 PM |
Might be worth doing a search on crush tubes?
