stevegough
posted on 11/4/09 at 08:45 AM |
I've got non- luego mushroom adaptor - Sorted.
bought these sierra front upright adapters from OBP - they have a fitting hole in the middle. They were 15quid as opposed to the 100 luego charge -
only theirs has the hole off - centre. did a trial fit (no wheels or engine weight) and it looks like I'm going to find it hard to achieve any
negative camber. Has anyone else tried these - see photos
[Edited on 17/5/09 by stevegough]
![](/galpreviews/a924239-KitsBits mushroom 004.jpg) ![Rescued attachment KitsBits mushroom 004.jpg](/gallery/a924239-KitsBits mushroom 004.jpg) Rescued attachment KitsBits mushroom 004.jpg
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
stevegough
posted on 11/4/09 at 08:47 AM |
this is luego's eccentically - holed boss
Luego Locost C20XE.
mistergrumpy
posted on 11/4/09 at 08:55 AM |
Yes I've got the blue ones. I can't see how you're not going to get camber though. Can you not just screw the top ball joint back
into the top arm to get your camber.
tomgregory2000
posted on 11/4/09 at 10:39 AM |
I understand your problem.
I have the offset adaptors on my viento and if i didnt i would have positive camber, it looks like the top wishbones have been made to long and im
going to trim the end of the bone back with the angry grinder, only about 10mm with the offset adaptors fitted.
I think the only option is new shorter top bones, i will remake my top bones over the winter.
Tommy
g.gilo
posted on 11/4/09 at 12:36 PM |
top hats
beware the offset ones are also offset on the c/l axis. e.g. the taper is not paralell to the o.d.
i think u run out of articulation on some ball joints without the offset.
graham
Andybarbet
posted on 12/4/09 at 11:26 AM |
I got my ones from MNR for my luego, still not built but they are offset and at 37 quid, much more reasonable than the luego price when i got my kit
about 4 years ago.
MNR are great to deal with too.
Hope you manage to get round th problem
stevegough
posted on 14/4/09 at 04:03 PM |
Tried MNR today, you are right, they are very helpful, but he said they haven't stocked the sierra conversion bosses for over a year! (even
though they are still advertised on their website).
Looks like I'm going to have to get the 24 carot gold plated ones from Luego!
Luego Locost C20XE.
stevegough
posted on 12/5/09 at 09:39 PM |
got the ones from Luego - they are not quite the same now, I don't think, and Ben only charged me £80 all in.
The offset taper is now parrallel to the boss's axis - reference the reply I think g.gilo mentioned
this?
Luego Locost C20XE.
bill132hotrod
posted on 13/5/09 at 11:33 PM |
negative camber
Hi guys
I also had this problem, and was told by Ben that there was a maufactureing problem with the old luego, i could only achieve 3deg of possitve camber
(no negative at all this was overcome by new lower wishbones now supplied by Ben and they are a good 1" or so longer so now can easily achieve
negative camber.
wilkingj
posted on 15/5/09 at 07:46 AM |
Also watch the top ball joints. Some do not have thread all the way along them, so you cant screw them fully in, thus limiting the camber as well.
So check they are fully threaded before you buy the top joints.
Every little helps when it comes to camber and castor!
Did Ben say whether it was the top or bottom arms that they changed?
Best Regards
Geoff
http://www.v8viento.co.uk
bill132hotrod
posted on 15/5/09 at 12:08 PM |
top mushrooms
Qoute. Ben has had the (bottom) wishbones changed / Modifyed.
PERSEVERANCE is the word of the week. Stick with it the results are SWEET.
