Scotty
posted on 7/6/09 at 09:48 AM |
alternator light comes on
hi guys
have a niggly little problem
while driving around the alternator light filickers, sometime stays lit for a time (eg 5 mins) have a volt meter in dash and this seems constant at
14v even with the light on solid
never a problem with the battery or starting the engine
any ideas what might cause this?
cheers in advance
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
Xtreme Kermit
posted on 7/6/09 at 10:56 AM |
I would always advise checking all connections right from each contact on the alternator through to battery + starter + earths.
Remember that the ignition light is usually connected to 12v on the battey side, and 13+ volts on the alternator side. If one side drops, the light
comes on.
If if is coming on like that, I guess it could be the rectifier??
posted on 7/6/09 at 11:25 AM |
Alternator drive belt a bit slack, or oily/greasy?
jollygreengiant
posted on 7/6/09 at 12:31 PM |
I suspect faulty rectifier pack, keep an eye on your voltage becuse eventually it will either fall away and stop chargeing or start over chargeing and
boil the battery/cook electric cables.
WestfieldSEI
posted on 7/6/09 at 01:57 PM |
Its probably one diode in the rectifier packing up....
Scotty
posted on 8/6/09 at 06:36 AM |
ok chaps
thanks for that
sounds like i'd better get alternator checked
cheers
