Author: Subject: Viento engine mount mod
kenton
posted on 26/6/09 at 07:55 PM Reply With Quote
I'd noticed that the exhaust manifold was lower where it exits through the side panel, compared to where it was originally. I thought the engine mount rubbers had compressed, however on closer inspection the engine mounts had bent by the block bolt-holes. I've straightened the mounts and added a cross-member that runs under the engine supporting the mounts. Rescued attachment IMG_6225.JPG
clairetoo
posted on 26/6/09 at 07:59 PM Reply With Quote
Is it me , or is that sump really that close to the ground
Its cuz I is blond , innit
Claire xx
Will weld for food......
speedyxjs
posted on 26/6/09 at 08:18 PM Reply With Quote
Thats what i was thinking
How much clearance do you have kenton?
kenton
posted on 26/6/09 at 08:20 PM Reply With Quote
I have about 4" clearance. My girlfriend bless her often says when we arrive at a speed hump "shall i get out"
stevegough
posted on 26/6/09 at 09:15 PM Reply With Quote
Sorry, gotta take issue with that 4" - on the photo it looks like an inch and a half max. - Or is it trick photography?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
clairetoo
posted on 26/6/09 at 09:21 PM Reply With Quote
4 inch's - looks more like 4 centimeters
Claire xx
kenton
posted on 26/6/09 at 09:50 PM Reply With Quote
The front wheels are part way down the slope out of the doorway so sump looks lower than it actually is.
Paul (Notts)
posted on 27/6/09 at 09:27 AM Reply With Quote
Any pics of the engine mounts and where they were bending..
Paul
jacko
posted on 3/7/09 at 07:57 PM Reply With Quote
How do you drain the oil the plug looks half way up the sump?
Jacko
darrens
posted on 4/7/09 at 09:49 AM Reply With Quote
I did exactly the same mod after I broke an engine mount at Croft.
