jollygreengiant
| posted on 29/6/09 at 09:08 PM |
Problem day
Well took the car out to go up for my hackney carriage medical today (£110 pre paid to quacks when you book it) .
On the way up the throttle linkage came off the butterfly spindle. Common problem on the Ford Sierra EFI, but easily fixed.
Had medical, came out to car and ............................................................................................................
Whats black and drips from the bottom of the engine, leaving a pool of shinny black stuff about 2 foot in diameter.????
Hey ho engine out.
tomgregory2000
| posted on 29/6/09 at 09:17 PM |
Hey ho engine out.
To put a bigger one in
NeilP
| posted on 29/6/09 at 09:18 PM |
Pinto Shminto - Time to up the bores me hearty!
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
DavidM
| posted on 29/6/09 at 09:19 PM |
Sorry to hear that Clive. Where is it coming from? Is it a seal or have you broken something?
Proportion is Everything
graememk
| posted on 29/6/09 at 09:31 PM |
"hazmat" hope you cleaned up the oil
jollygreengiant
| posted on 29/6/09 at 09:54 PM |
Looks like from the bottom off the sump below the drain nut, will know more tomorrow after jacking up wiping & inspecting. I suspect that it is
from that little divot just below the nut where on occasions I have had ground clearance 'issues'.
blakep82
| posted on 29/6/09 at 10:10 PM |
quote: Originally posted by jollygreengiant
Whats black and drips from...
thought this was the start of a joke about traffic wardens. the uniform's black isn't it? don't know what drips from them right
enough. smugness i guess
________________________
jollygreengiant
| posted on 4/7/09 at 11:49 AM |
Ok, so now I've had time to stop panicing and actually think and do something about this.
Car is now up on axle stands again, so an ideal opportunity to do the springs and wishbone bushes while I sort out the sump.
Inspection shows that the sump actually sits about an inch plus below the bell housing. Driving the car has modified the bottom of the sum and hence
holed it (pin hole) just below the drain plug. So this looks like it is also an ideal opportunity to modify the sump. This (in conjuction with new
rear springs and hence slightly higher ride height) should solve the ground clearance and scraping sump problem.
When I originally said engine out I was still thinking in terms Sierra/Granada engine. Idiot. The sump access is a doddle as it now drops straight out
the bottom (NO CROSS MEMBER to get in the way is there).
All being well I should be back on the road next weekend(ish).
Browser
| posted on 14/7/09 at 04:47 PM |
quote: Originally posted by jollygreengiantWhen I originally said engine out I was still thinking in terms Sierra/Granada engine. Idiot. The
sump access is a doddle as it now drops straight out the bottom (NO CROSS MEMBER to get in the way is there).
Well, I was wondering, but since you've had the good grace to call yourself and idiot.........
Hope it gets sorted soon mate.
