bj928
posted on 10/11/09 at 09:48 PM |
v10 viper stoppers fitted
Made up the brackets to fit the calipers today, don't they look nice, only made the template out of MDF so far but they look good.
for those that like to know the numbers
330mm discs, 6 pot calipers, 18" wheels 9J depth
[Edited on 11/11/09 by bj928]
A1
posted on 10/11/09 at 09:54 PM |
nice...
posted on 10/11/09 at 10:16 PM |
Way-hay... now that's a pair of brake calipers!
It's Evolution Baby!
posted on 10/11/09 at 11:08 PM |
nice .... but you sure you not got it upside down - bleed nipple should be uppermost?
bj928
posted on 10/11/09 at 11:19 PM |
thats just the caliper we grabbed, it should fit the other side the other way up, either caliper can go on either side because they are radial mounted
( think thats the term )
blakep82
posted on 10/11/09 at 11:22 PM |
makes me moist!
________________________
speedyxjs
posted on 11/11/09 at 08:05 AM |
Nice!
posted on 11/11/09 at 09:07 AM |
makes me moist!
And that thought just made me queasy!
MK9R
posted on 11/11/09 at 10:32 AM |
Now that should stop on a sixpence!!
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Liam
posted on 11/11/09 at 10:53 AM |
Or at least lock the wheels with the weight of a sixpence on the brake pedal Car'll just carry straight on with that anchor in it
(No, I'm not jealous)
steve m
posted on 11/11/09 at 04:22 PM |
!Or at least lock the wheels with the weight of a sixpence on the brake pedal Car'll just carry straight on with that anchor in it !
Liam, i am with you on that, as even my book built locost with 4 pot calipers lock the front wheels up before actually slowing the car up,
and that is with out a servo and mk2 escort master cylinder
Project7
posted on 11/11/09 at 05:17 PM |
But they will take some punishment before they start to fade!
bj928
posted on 11/11/09 at 07:44 PM |
making the final fit brackets making sure everything lined up, realised rally design have given the wrong size disc, looks to be a 323mm not the 331mm
it should be, not sure if both sides are wrong, will check tomorrow, spoke to rally design and they going to sort it tomorrow, lucky the car is only
half a mile from their new shop , realized something was wrong when i had a 10mm overhang on the pad, inside edge of pad was spot on, outside edge
finnished 10mm outside of disc.
don't think it will lock up the front to easy, will be running 255 toyo R888's and have a great big v10 weighing down on the front to keep
them turning, no servo, tilton peddle box and master cylinders.
and for those that noticed the caliper upside down, useing the correct one now, lucky they were radial mounted so can be swapped side to side.
bj928
posted on 12/11/09 at 08:45 PM |
well got it sorted, now running 355mm discs, the surface area on the 330mm discs was 40mm but pads needed 50mm, had a look at the 355mm discs and they
had the 50mm needed, so, as it was rally designs misinformation, they let me have the new discs for the difference in price between the 2 sizes, so
£40, got to pop the 330mm discs back to them and they are sending them back to wilwood for a refund, as they had been told they fit and they obviously
don't, they think it might be that the 330mm discs listed for the calipers have a different bell and disc setup thus giving the 50mm surface
area needed.
bj928
posted on 22/11/09 at 06:59 PM |
well got the rear discs and calipers on her today, also got the electro magnet power wire out the diff, also got the diff sealed and ready for oil, so
the running gear all sorted
this is the diff, decided to bring the wire out the breather.
NeilP
posted on 25/11/09 at 10:46 PM |
Gulp - I'm scared - It's really coming to life - we might all prefer the static version that makes a hellish racket!....
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
