Steve_H
posted on 11/4/04 at 10:26 PM |
Newbi (therefore advice required!)
I am very close to taking the plunge and odering myself Velocity Kit but I would like some advice.
I know this is a how long is a peice of string type question but how much will it cost from start of build to it being finished? I imagine there are
plenty of hidden costs that I won't realise exist.
Also any other tips/advice would be greatly appreciated!
Browser
posted on 12/4/04 at 03:57 AM |
That Steve, is one of the great imponderables and is you do a search on budgets or similar you will find a LOT of threads on the subject. It all boils
down to (a) how much you can make & recondition yourself (b) how good you are at getting bits fer next to nowt and (c) how much you are prepared
to spend. If yo ujust want a budget car powered by a bog standard Sierra engine, with steel wheels & a basic interior you should be able to
do something for as little as £2000. Most folks (I think) are looking at between £3500 and £5000. If you went the whole package route buying every
component from Luego I think its about £8000? All depends what you want at the end of it.
posted on 12/4/04 at 10:36 AM |
Costs
The recent poll (at this time) seems to indicate most builders estimate £6K+, but obviously it depends on:
1. How innovative you are
2. How resourceful you are
3. What you want at the end of it
Good luck!
JoaoCaldeira
posted on 12/4/04 at 02:07 PM |
Hi.
Just done the sum of (almost) everything, considering all Luego packeges. LHD [+50] BEC [+300] build. It's nearly 7650 + donnor + wheels &
tires.
I think Luego is a bit expensive than compared to others (ST, MK) but [hopefully] quality and support are a plus.
Joćo Caldeira
