Cubby
| posted on 1/3/10 at 05:11 PM |
MT75 Gearbox Mount
Hi Guys,
Does anyone know where you can get an uprated Gearbox mount for the mt75 Sierra?
big_wasa
| posted on 1/3/10 at 05:17 PM |
Should be the same as the t9
I made my own
mcerd1
| posted on 1/3/10 at 05:25 PM |
I thought they were the same too - so assuming you've got this type at the moment:
you could try one of these as a starting point:
thats the 4spd type as used by westfield and caterham (weirdly caterham are one of the cheapest places to get them )
the are a bit smaller than the 5spd ones, so you'll need to do a little work to make it fit
I can give you sizes for either type if you need them...
stuart_g
| posted on 1/3/10 at 05:42 PM |
Westfield use two bobbin type mounts with sleeved nuts to attach to the gearbox.
Picture of item
Linky to item page
turbodisplay
| posted on 1/3/10 at 05:44 PM |
burton power do them, about 70 pounds, but very strong!
Darren
Cubby
posted on 1/3/10 at 05:48 PM |
cheers guys,
could you tell me the sizes if poss?? (centre to centre hole dimension)
mcerd1
| posted on 1/3/10 at 06:53 PM |
done some quick measurements just now give or take 0.5 of a mm
5 spd mount: 142mm ctr to ctr
4 spd mount: 94mm ctr to ctr
(upside down in pic)
its also worth noting the 4 speed mount is slightly taller ~18.5mm from the bottom to the top of flat in the middle
(i.e. 4.5mm higher than the 5 speed one)
[Edited on 1/3/10 by mcerd1]
Cubby
posted on 1/3/10 at 07:08 PM |
Thanks for the info .Much appreciated.
mcerd1
| posted on 1/3/10 at 09:03 PM |
forgot the link: mount
