Author: Subject: Help, twitchy drive.
dogwood
posted on 17/4/10 at 04:21 PM Reply With Quote
Just finished my Haynes Roadster.
Took it out for a quick spin.
Found it almost undrivable, due to it's twitchy handling.
Cant take it above 60 wthout it tryin to throw itself into the hedge..
I know the tracking is ok.
So any ideas, obvious or obsure.
[Edited on 17/4/10 by dogwood]
FREE THE ROADSTER ONE…!!
jacko
posted on 17/4/10 at 04:24 PM Reply With Quote
tyres to hard ? i run mine at 18psi
zilspeed
posted on 17/4/10 at 04:31 PM Reply With Quote
Caster
Tyre pressures
Damper settings
Are the three place I would start.
you say the tracking is ok, what is it set at ?
dogwood
posted on 17/4/10 at 04:36 PM Reply With Quote
About 1deg toe in
sebastiaan
posted on 17/4/10 at 04:41 PM Reply With Quote
rear toe out? should be neutral or slight toe in
posted on 17/4/10 at 04:43 PM Reply With Quote
Ride height?
The rear should be higher than the front - I think my Locost is 5.5" floor to chassis at the from, and 6.5" at the rear (before the chassis tilts up). Convert to metric if it makes you feel better!
I can't speak for the roadster's measurements, but I bet they won't be much different.
It can be quite evil if the front is higher than the back, especially at speed.
dogwood
posted on 17/4/10 at 04:51 PM Reply With Quote
What's the consensus on tyre pressures.
Pinto lump up front, fat lump at the back..
I know Jacko says 18psi.
I think I'm set at about 25psi all round
ashg
posted on 17/4/10 at 04:54 PM Reply With Quote
100% sure.... not enough toe in. guess how i know that. bet the turn in feels good at lower speeds lol.
20psi max on the tyres sent you a message on haynes with a link to something.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Paul TigerB6
posted on 17/4/10 at 05:41 PM Reply With Quote
I'd say 17-18psi too - 25psi is wayyyyy too much even with the boat anchor in the front.
Jon Ison
posted on 17/4/10 at 06:06 PM Reply With Quote
plus bump steer if your confident the front geo is correct, does it have a lsd ? if so is it acting up ?
dogwood
posted on 17/4/10 at 06:12 PM Reply With Quote
No lsd.
Bumpsteer, hadn't thought of that.
I'll have to check the rack alignment tomorrow
tomgregory2000
posted on 17/4/10 at 06:54 PM Reply With Quote
i wonder if the rack has been centered?
dhutch
posted on 17/4/10 at 07:23 PM Reply With Quote
I run about about 18psi, cvh up front, bean pole in the drivers seat.
Chippy
posted on 17/4/10 at 09:35 PM Reply With Quote
I run 18 PSI all round, and thats with a V6 hanging around up front and a lump of lard in the driving seat, Ray
James
posted on 17/4/10 at 11:41 PM Reply With Quote
My tyres are set to 18psi too and handling was pretty good and all shocks on softest.
Then, because the rear wings were set too low and were hitting the tyres on bump, as a quick fix, I set the rear shocks to hardest. The results was every bump the back tried to jump in the air!
Could this be your problem?
James
Vindi_andy
posted on 20/4/10 at 11:07 AM Reply With Quote
So you finally got her finished Dogwood.
Well done that man. Im guessing we wont be seeing her at stoneleigh but will we see you? Have to share a beer
Tango will be making her first trip to stoneleigh this year, didnt quite get her registered in time last year
dogwood
posted on 20/4/10 at 05:24 PM Reply With Quote
Hi Andy.
Long time no hear.
Yea I'll be at Stonleigh, with the car.
I'll be on the locost stand, with the other Haynes guys.
I hope to see Tango in the flesh.
Often wondered how it turned out.
Later mate
Vindi_andy
posted on 21/4/10 at 08:35 AM Reply With Quote
Heard some interesting things about vindicator and stoneleigh so I doubt I will be on their stand. May well gatecrash the Rhocar stand as I have been to a few of their local meets and know a few of the guys there but will make a point of coming to the Locost stand and making my face known.
Ill let you know where tango will be hiding
