kylerichmond
posted on 20/6/10 at 10:12 PM |
bike carb noise
I have a zetec fitted with zx9carbs, however when the engine is running the carbs make a sqweeking noise in tune with the engine, is this normal? Or
is it a leak or something?
55ant
posted on 20/6/10 at 10:14 PM |
sounds like an air leak, have the engine running and if you spray wd40 around the join/gasket it goes quiet and you can locate the leak hopefully.
away from cars, now cycling and building TT bikes
rayward
sound like your sucking air in somewhere, try spraying wd40 or easy start around the rubbers, if your engine note changes you have a leak !
hth
Ray
austin man
posted on 20/6/10 at 10:40 PM |
you do tend to get a strange induction noise from the zetec It sometimes sounds like you can hear the valves Ive noticed it on my car with twin
40's on and one running Injection but with bike carbs as TB's
omega0684
posted on 21/6/10 at 07:17 AM |
if you have an air leak it normally sounds like a birdy tweeting
