phil4521
| posted on 26/6/10 at 11:50 AM |
Ford steering rack extenders for Viento.....
It looks like (unless I'm hugely mistaken) that the rack extenders I got from Luego with the kit 3 years back are too short. The problem is that
with the tracking set there could only be about 3.5 mm engaged on each side, and that's with the steering wheel not straight.
This is what I've done so far- With the nearside wheel set to parallel the steering rack end is actually out of the extender, (this is with the
steering wheel held straight ahead), with the off side wheel parallel the rack end is only engaged 7mm, hence what I say above as the 3.5 each side
being the best case scenario, and it really isn't enough.
The extenders are 110mm long and really need to be 120mm.
Ben Lord at Luego will sell me a 130mm set for £40 but I dont know if this in the only source? Any ideas?
big-vee-twin
| posted on 26/6/10 at 11:56 AM |
Assuming its an escort rack, Rally Design sell them
http://www.triangleltd.com
l0rd
| posted on 26/6/10 at 02:20 PM |
I should assume that they should provide the correct ones with the kit and not ask for extra money to send the correct ones.
wilkingj
| posted on 26/6/10 at 05:04 PM |
Careful here.,... the Viento ones are longer than the std Se7en ones, cos its much wider, and still uses the escort rack.
I would speak with Ben at Luego, he may exchange them for the cost of the postage. Certainly worth a try.
Best Regards
Geoff
http://www.v8viento.co.uk
| posted on 26/6/10 at 06:18 PM |
Flakmonkey may be able to help?
repper
| posted on 27/6/10 at 05:11 PM |
ive got the same problem with mine the tracking is not able to be set corectly as the rack extentions in got from luego are to short but as i got them
from the last owner befor ben ive not yet done any think about it i have noticed that rally design do difrent lenthe ones may be worth a call to ben
