Author: Subject: Dread side repeaters
Michael
posted on 4/7/10 at 10:02 PM Reply With Quote
I have looked at moving my side repeaters over the weekend, but the ones i have are to big for relocating on the wings.
I found someone the bay that are 75mm in lengh and 25mm high (from surface)
I have the same in clear at home, but there are no E marks.
Do they have to be E marked for IVA?
big_wasa
posted on 4/7/10 at 10:06 PM Reply With Quote
Ive just fitted mine in the rear wings today.
They are tiny and well out of the way there.
only about 20mm dia with hole of 16mm.
will take a photo tommorrow if you want ?
Bought at Newark for £12 but also sold by Gbs on ebay.
bigpig
posted on 5/7/10 at 07:34 AM Reply With Quote
I got a couple of the little round LED repeaters from GBS and mounted them on the outside of the rear wings and come with rubber mounting.
MK use some rather large ones, which they put on the outside of the front wings.
Stott
posted on 5/7/10 at 09:20 AM Reply With Quote
Only the rear fog needs to be E marked for IVA, nothing else
40inches
posted on 5/7/10 at 11:01 AM Reply With Quote
I have used these from GBS, £8 inc postage. If you are fitting them on the wings(front or rear), you don't necessarily need the rubber sealing bush, they look very neat without
gavin174
posted on 5/7/10 at 11:30 AM Reply With Quote
i fitted mine in the side of headlight bowl
you can buy them CBS done like it now
seem to remeber side repeaters have to be within a certain distance of front of car..
2.4m i think
bi22le
posted on 5/7/10 at 11:44 AM Reply With Quote
I thought all lights had to be E marked or equivalent. I have not IVA a car though so dont quote me.
I have seen a few cars now with indicators on the rear arches. Seems a tidy mod.
Please read my ring story:
40inches
posted on 5/7/10 at 12:29 PM Reply With Quote
E markings only needed on rear fog lamp, other lamps need to be the equivalent rating in terms of brightness, however it makes sense to fit E rated main lamps otherwise you are at the testers mercy, because it is down to his opinion
Michael
posted on 5/7/10 at 08:01 PM Reply With Quote
I have ones that CBS sell but got them from Premier Wiring yonks ago.
They are to big for the area on my rear arch so looking at getting smaller ones for IVA.
Michael
posted on 9/7/10 at 09:03 PM Reply With Quote
Do you need a special relay for these?
stevegough
posted on 30/7/10 at 07:59 PM Reply With Quote
As I understand it, the flasher circuit relies on receiving a signal in the form of a current drain (usually provided by the usual standard bulbs) for the flasher circuit to operate. In the case of LEDs, however, because the current is so tiny, the flasher unit doesn't get its feedback, so the flasher doesn't work. The usual way round this is to put a resistor in the circuit to produce the normal current drain.
In this case though, as they are only LED repeaters, the drain is provided by the standard back and front bulbs, so the resistors wouldn't be needed.
HTH, Regards, Steve.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Michael
posted on 30/7/10 at 08:24 PM Reply With Quote
I brought a couple of Land Rover Defender ones off the bay 2 weeks back for £4.50 each.
Fitted them last Saturday afternoon on there rear wings.
Thanks people
