bj928
| posted on 12/11/10 at 04:03 PM |
front track
Anyone know or can measure the front track of a viento, where is the track measured from and to, my rear track is standard mustang cobra and that is
said to be 60 inches, guessing front will be less.
speedyxjs
| posted on 12/11/10 at 05:39 PM |
I think it is the distance between the centre of each wheel (wheel, not tyre).
kenton
| posted on 12/11/10 at 06:40 PM |
Front 57 1/2 "
Rear 62"
(measured by tape on floor, center to center)
kenton
PSpirine
| posted on 12/11/10 at 10:44 PM |
speedyxjs, you're right and wrong.
It is measured to the centre of the wheel. But the centre of the wheel is the same as the centre of the tyre (unless you've got some properly
insane tyre mounting configuration! ).
To clarify, that means to the centre of the wheel - halfway between inside and outside - NOT to the wheel/hub mounting surface.
bj928
| posted on 13/11/10 at 12:07 AM |
bugger, thats about 10 inches to narrow for my idea, looks like i could be norrowing the front axle to get it to work
