Irony
| posted on 10/12/10 at 11:16 AM |
Lt77 Speedo Drive
Only a couple more jobs and my V8 is going in! Just praying I have put it together right. Couple of bits I have got to sort are:
Bell housing to block bolts
Gearbox Oil.
Speedo Drive
There is a huge hole at the back of the LT77 that I think is for the original speedo drive. I was thinking I would need some sort of blanking plate
for this as I was intended to not use Rover instruments. What did you guys do????
Going to Rimmers tomorrow so if you guys think of anything else.........
wilkingj
| posted on 10/12/10 at 12:26 PM |
Used the std Rover electronic sender, with a Caerbont (from greengauges.co.uk) speedo, works well and is one of the best calibrated speedos the SVA
man had seem for a while. ie dead on at 30 and 70mph.
Best Regards
Geoff
http://www.v8viento.co.uk
scudderfish
| posted on 10/12/10 at 12:56 PM |
Standard gearbox with a 80mm speedo from ETB Instruments. Needed a resistor adding into the circuit, but it is fully documented/diagramed on the ETB
website.
robinj66
| posted on 10/12/10 at 05:52 PM |
This might help with the bellhousing bolts linky
The electronic senders for the LT77 are hard to find and expensive. If you don't need to use it then just blank it off with a metal disc and a
circlip.
This might help re the gearbox oil linky - I would have a search
around that site for other thoughts on the gearbox oil
