Author: Subject: PASSED
Michael
posted on 18/4/11 at 09:02 PM Reply With Quote
PASSED
Had my IVA retest this morning at Micham.
I passed after 20 minute walk around. Was meant to be tested at 11, sat waiting and then went in at half 10 to pay ready for the test and was then waiting at 11 for the certificate.
I am happy, but it still not dawned on my as yet that once i have it painted i can drive it (well after its registered)
blakep82
posted on 18/4/11 at 09:09 PM Reply With Quote
you can drive it before its painted!
any pictures of it post test?
and well done
________________________
hootsno1
posted on 18/4/11 at 09:12 PM Reply With Quote
Well done that man, i got a long way to go only just finished drilling all the holes for the panels be for painting it.
stevegough
Well done! - passed with a windscreen, too? Good man - join the club. And, as Blake says, drive first, paint later!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Daddylonglegs
posted on 18/4/11 at 09:19 PM Reply With Quote
Well done that man!
I just hope I am smiling before too much longer. I often wondered if people had put their cars in before painting. I intend to paint before IVA, but that's just because I think that if it's presented well there is a better chance of a positive test result because it looks more like effort has gone into the build.
I know that the test should be the same result whether or not it looks good on the outside, but I'm sure appearance does make a difference at most centres.
ali f27
posted on 18/4/11 at 09:30 PM Reply With Quote
Well done enjoy the feeling and yes take it out for spin
Confused but excited.
posted on 18/4/11 at 10:13 PM Reply With Quote
Congratulations!
Michael
posted on 20/4/11 at 08:26 PM Reply With Quote
Yes I had read the posts about having it painted before test, but had always had the idea in my head of paint after test incase there are any mods required or brackets changed etc.
I was right. I had to remake steering rack mounts, to add bracing and so that it was secured with nuts and bolts to the mounts.
Also additional welding onto both lower outer seat belt mounts and weld roll bar to chassis (was held by 8 nuts and bolts - now has both)
Other then that it was a case of remaking dash, adding padded spare wheel cover and changing exhaust clamps and radius on tail pipe.
I did not have a screen on for test, but was fitted during the build so now just got to refit, adapt wipers (doing that at the moment) and fitting washers.
Then yes will be stripped to a chassis and painted. Paint is now ordered for the chassis.
Add to that I do need to get the glass cut for the screen I have the frame all set up and currently wood is in place of glass.
[Edited on 20/4/11 by Michael]
stevegough
posted on 20/4/11 at 09:56 PM Reply With Quote
Don't use wood in place of glass - it'll ruin your wiper-blades dead quick!
Luego Locost C20XE.
40inches
posted on 21/4/11 at 07:30 AM Reply With Quote
Originally posted by Michael
"and weld roll bar to chassis (was held by 8 nuts and bolts - now has both)"
Was this something you wanted to do or an IVA fail?
Michael
posted on 21/4/11 at 08:18 PM Reply With Quote
IVA Fail.
It was deamed that 8 bolts was not secure enough and wanted it welded to chassis.
40inches
posted on 21/4/11 at 08:37 PM Reply With Quote
IVA Fail.
Just about every 7 kit has bolt on roll bars, and I have never heard of anyone else failing, I think you got a jobsworth
From memory I think that Westfield's are fixed with a single bolt each side, might be talking borrock's though.
Michael
posted on 22/4/11 at 08:42 PM Reply With Quote
Yes i have to agree about not requiring the welding.
There was a disagreement between the guy and my dad but not a arguement, lol. As the tester said the Seat belt eye bolt threads were to short.
In the end he accepted them as they come with the belts that had all the right markings and that was even after ringing technical.
all in all though he was genuine and allowed adjustments and discussed what was required.
Shame i could not get it done sooner though.
