New Topic New Reply
Author: Subject: Indy Panel question
Jonte
posted on 24/7/04 at 01:41 PM Reply With Quote
Indy Panel question
I´m about to put my panels on the Indy and have some questions about it.
First of all. Is there some particular order that´s better then other when you put them on?
I was thinking about this order and fastening.
1. Sidepanels with glue and rivets
2. Rearpanel with glue and rivets
3. Nose cone (gonna do a flipfront)
4. Scuttle with rivnuts
5. Bonnet
How have you all done where the sidepanels meet the rearpanel?
Should they overlap or trim so they just meet?
See photo
Any other tips about this?
Click it
mookaloid
posted on 25/7/04 at 07:10 AM Reply With Quote
That is the order I used, I trimmed my panels on a vertical line so that they just met. the join is mainly hidden by the rear wings. You will probably want to round off the corner of the side panel to get it to meet the rear panel where the profiles don't match.
DEAN C.
posted on 26/7/04 at 12:52 AM Reply With Quote
Hi, my solution is to cut the side panel down in front of the roll bar and horizontally towards the back panel,about 1/2" down ,blends in fine.
If you're not sure I'll try and post a pic ...
DEANO........
Once I've finished a project why do I start another?
santcliff
posted on 26/7/04 at 06:59 AM Reply With Quote
I rivnutted the rear panel and arches. came in handy when i needed to change the fuel tank.
stuart
One o' cross beams gone owt askew ont' treddle
Jonte
posted on 26/7/04 at 09:55 AM Reply With Quote
DEANO........
A pic wouldn´t hurt
Click it
New Topic New Reply
