Author: Subject: Alloy Wheel Painting
Michael
posted on 7/8/11 at 09:03 PM Reply With Quote
Have brought the Acid #8 primer ready to paint my RS2000 wheels, but i read that after I applied the main colour it will need laquer (which I brought)
The thing is I brought gloss black paint and it says paint will need matting down with light glass paper before laquer.
So should I swap the gloss for matt black or just laquer over the gloss?
I have alloy silver paint too for the inner faces of the wheels and will laquer over that too.
Thank you.
austin man
posted on 7/8/11 at 09:37 PM Reply With Quote
generall the laquer will require you flat the paint work for a good key, let the paint harden then light flat with p 800 or p1000 dry thoroughly then laquer. If using cans I heat them slightly in a pan of hot water this increases the spray pressure
Mark Allanson
posted on 7/8/11 at 09:47 PM Reply With Quote
If you have bought gloss you wont need lacquer
MikeFellows
posted on 8/8/11 at 08:06 AM Reply With Quote
there is an accident waiting to happen there - please take photos of your kitchen when/if it does
[Edited on 8/8/11 by MikeFellows]
Michael
posted on 8/8/11 at 08:59 PM Reply With Quote
My thoughts too.
I will leave the laquer to room temperature, but Will laquer the back side of the alloy wheel that faces the inside of the car as that is being painted with wheel silver and it recomends a laquer over that.
RK
posted on 16/8/11 at 04:57 AM Reply With Quote
http://www.youtube.com/watch?v=0aV2H57bES4
Michael
posted on 20/8/11 at 01:34 PM Reply With Quote
How do you clean the old paint off? I have tried wire brush but can not get right in the corners.
The paint is realy thick in places with runs so I can not just paint over it.
macc man
posted on 20/8/11 at 02:50 PM Reply With Quote
Best way to remove old paint is to bead blast or use nitromores paint stripper. This is a messy job so blasting recommended.
spiderman
posted on 20/8/11 at 02:56 PM Reply With Quote
Heat the water in a pan remove from heat source and then put can in the pan of hot water. I have never had a problem doing it this way , presure increases, paint atomizes better and drying time is reduced.
[Edited on 20/8/11 by spiderman]
Spider
Michael
posted on 21/8/11 at 03:30 PM Reply With Quote
Do I need to protect the polished alloy area if I use Nitromor.
Thanks.
matt_gsxr
posted on 23/8/11 at 04:22 PM Reply With Quote
no need to protect polished area, but it does nasty things to the tyre if left on there.
Michael
posted on 23/8/11 at 07:34 PM Reply With Quote
Thanks.
Thats ok then as I have already removed the tyres so they can be completely refurbed.
Angel Acevedo
posted on 31/8/11 at 03:13 PM Reply With Quote
Maybe too late, but if you paint the interior, you reduce the possibility of leaks due to porous castings. (very rare now, but if you already have the tires out...)
Michael
posted on 31/8/11 at 08:16 PM Reply With Quote
Yes I have decided to remove the tyres so I cn paint the inside of the rim (what you wont see because tyre covers)
I did think too that it was a possibility as thats where its leaking through.
