carlknight1982
posted on 10/9/11 at 08:27 AM |
Road legal and dissapointed
I knew there would be some teething troubles but i have to admit im devestated. first road legal run in the car, got her upto 55mph and watched the
temp gauge hit 105 degrees, WITH the rad fan running! that wasnt the worst tho, I just couldnt get my knees into a position where they were
comfortable under the dash, how taller builders fare i dont know! specially spud at over 6ft!
Im going to try to move the seat back a little, but again this isnt the worst issue, the worst issue is the clutch is slipping like a bastard at
anything over half throttle above 40mph and forget 5th gear completely.
Plans for the weekend are to fit a new thermostat to help with air locking problems and hopefully cure the overheating, move the seat back if possible
to give me a little more clearance around my knees, if not i may have to trim the bottom edge off the dash, and try to adjust the slip out of the
clutch but maintain a decent pedal.
all in all not as bad as it could be just a kick in the nuts
Logic will get you from a A to B
Imagination will take you everywhere.
StevieB
posted on 10/9/11 at 08:46 AM |
Is it only just IVA'd?
I wouldn't worry about it too much - when I got my Indy through SVA it was only the start of the work really, though it was a breath of fresh
air getting everything set up how I wanted it, rather than how the VOSA man wants to see it.
There's always a few tweaks needed once you've been out on the road and/or track a few times, but that's part of the fun of these
cars (so I'm told )
mistergrumpy
posted on 10/9/11 at 09:10 AM |
God yes. There's still now things I'm straightening out after my SVA in 2009. My clutch has been apart that many times we're pushing
double figures. It's something to be expected although yes I agree it is a kick in the balls, especially when you hear of people on here
travelling miles and miles to shows or whatever and like me you've struggled to get past the top road
posted on 10/9/11 at 09:12 AM |
check the thermostat ion a saucpan of boiling water first, I didn't and fitted a new thermostat that killed my expensive ported and unleaded
cylinder head.
re: steering wheel - option are to fit smaller one 11 or 10 inch is about as small as you'd want to go; aslo see if you can more the steering
column upwards.
adithorp
posted on 10/9/11 at 09:29 AM |
Don't worry, we all have teething problems and you'll soon get them sorted.
Temp... Was the rad hot at both the top and bottom hoses when it overheated? If not it's probably just a stuck shut 'stat. Are you sure
the gauge is accurate? An infra-red thermometer will confirm the figures.
Seats... I see you have padded ones.They're not the slimmest and GRP shell seats give more room but the max space is offten with a seat back
fitted to the bulkhead and a squab on the floor. Have you changed from the donor steering wheel? That will give you a lot more room as well.
Clutch... Do you have free play in the cable/pedal? If not it'll slip and is a common mistake. Is the release lever coming all the way back and
fouling on the end of the hole in the bell-housing? Again a common problem where components have been mixed and matched.
http://jpsc.org.uk/forum/
carlknight1982
posted on 10/9/11 at 10:24 AM |
Thermostat has just been changed, i checked it, it wasnt stuck but was a 92 degree stat so ive changed it with a 88 degree stat.
still over heating, ive checked the temp against my infra red thermometer and its spot on. not looking good, im hoping for an air lock.
its not the steering wheel that the problem its the bottom of the dash, im a big fella so like the padded seats but might have to have a chat with
triton.
as for the clutch i will take a peak at that tomorrow as the kids are playing up now
Steve Hignett
posted on 10/9/11 at 10:44 AM |
If you are a big guy, then I suggest you take a good a very close look at DIY Seat Making/forming isntead of buying a seat...
There are two methods:
Expanding Foam;
http://forum.caterhamracing.com/index.php?showtopic=149
Beads;
http://www.dpr-motorsport.com/accessories/real_essential_seat.html
bigbravedave
posted on 10/9/11 at 10:48 AM |
the biggest disheartener for you is probably down to seat position. Before I moved mine back the whole driving experience felt awkward, Im over 6 foot
and Im used to driving the 5'2 wifes car without moving the seat in hers.
once moved the foot angle on the pedals was loads better and more importantly I cud get on the brakes confidently without my knee catching the
steering wheel! and didn't get cramp in my left ankle
adithorp
posted on 10/9/11 at 11:38 AM |
Looking at your archive photos looks like a polo rad'. That should do the job so other things...
Is your fan rotating the corect way? From the photos it should be anti-clockwise as you look through the nose. Have you baffled around the rad to
force all the airgoing through the grill, through the rad? Are your pipes connected the correct way?
Top hose (thermostat) to top of rad
Bottom hose (from w/pump) to bottom of rad.
Air bleed/vent on rad along with air bleed/vent from top of engine to top of expansion tank .
Bottom hose from tank into bottom rad hose (but top hose will work).
Level in the bottle higher than the highest cooling part of the engine (usually the breather vent).
posted on 10/9/11 at 12:12 PM |
Venting the rear of my bonnet dropped the temperature by at least ten degrees , Some Pinto thermostat housings had a take off for a bleeder to the
header tank , If yours has one check it isn't blocked or if it is plugged can you connect it to the header tank? As for the driving position put
the seat into a position that is comfortable for your legs/feet and if required move/change the steering wheel to give a comfortable position then if
needed perhaps look at fitting a gearlever remote to sort that out. One of my old bosses had a Robin Hood that I couldn't reach the pedals and
the steering wheel almost hit me in the chest, all stuff that can be sorted! Has the clutch cable got any free play ?
snakebelly
posted on 10/9/11 at 04:16 PM |
have done a couple of bead seats now and they are very easy to do and as long as you take your time the end result is well worth it, some black cotton
cloth and a can of spray glue and they can look good as well.
iank
posted on 11/9/11 at 03:34 PM |
Making a foam and bin bag seat isn't hard - and it's a common upgrade on Caterhams (for those that don't go down the tillett carbon
fibre route )
Better link (IMO ) http://www.locostbuilders.co.uk/viewthread.php?tid=152517
Like most DIY, if you spend time getting things right and thinking things through you can do as good a job as any expert.
Anonymous
RK
posted on 11/9/11 at 04:02 PM |
There is some beautiful work there, but I see so many ways for this to turn into complete garage disaster, which makes it something I MUST try! Of
course, this is coming from the guy who just turned his garage into the Alberta Tar Sands. I never knew about the advantages of Kitty Litter until
yesterday.
MikeR
posted on 11/9/11 at 08:52 PM |
Seriously - wear old clothes, tuck everything into everything else!
(you can guess how i found out!)
Ninehigh
posted on 11/9/11 at 09:01 PM |
Does your seat come with a ridge where your coat/belt/something else was?
