SteveWallace
| posted on 6/11/11 at 04:14 PM |
latest Viento build pics - BMW engine in
Thought that I would upload my latest build pictures. Having modified the sump and made some new engine mounts, my BMW 2.8 engine now fits. The car
is not on its wheels yet, but I reckon that I have about 80mm ground clearance to the sump and about 10mm clearance between the top of the engine (the
oil filler cap) and the bonnet.
Team Dynamics Pro Race 1.2's are on order, so it should be on its wheels (but with lots of bits still missing!) in a couple of weeks. Next job
is to work out what on earth all the wires and connectors on the BMW engine loom are for.
Andybarbet
| posted on 6/11/11 at 04:16 PM |
That looks a good fit in there.
Nice job
dlatch
| posted on 6/11/11 at 04:26 PM |
great engines and if i was scratch building it would be exactly the same
NeilP
| posted on 6/11/11 at 04:33 PM |
Looks great and very comfortable - room for a supercharger!....
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
SteveWallace
| posted on 6/11/11 at 04:39 PM |
once its on the road, the first tinkering job is the wide bore throttle body and inlet manifold for an extra 30bhp for not much effort or cost.
Paul (Notts)
| posted on 6/11/11 at 06:40 PM |
Looks very snug.. Still lots of space in front of it.
Once its up and running you may need to look at some form of engine stay at the top to reduce the movment of the heads. Depends how close they are to
the chassis rails and how close the exhaust is.
Will pop over to have a look soon in the kit if thats OK.
Paul
SteveWallace
| posted on 6/11/11 at 09:09 PM |
Paul,
There is very (very) little clearance between the side of the sump and the chassis so the engine will have to have very little movement.
Pop over any time. I'll send you a U2U with my phone number and address.
regards
Nickp
| posted on 7/11/11 at 08:39 PM |
Looking good there Steve!!
Wish I'd seen your build threads before now for inspiration. I've just started squeezing an M52 into a Haynes chassis. Did you have to
modify the transmission tunnel at all? I'm using the original mounts and have got the engine as far back as possible for good weight
distribution (hopefully!!) I've done similar with the sump but at the moment just have a right angle cut out of it, ready to be welded soon.
There's some pics over here - http://www.ppc-mag.co.uk/forum/viewtopic.php?f=7&t=9383&sid=cbcfbf228a5688c7e0a5bee7d3edfc9f
I'll be watching your progress closely and hopefully picking up a few tips
DixieTheKid
| posted on 7/11/11 at 08:54 PM |
Good job steve, looks like very little movement for error. Is that an M52?
COS IT'S Worth IT
SteveWallace
| posted on 8/11/11 at 09:40 PM |
I've not had to modify the transmission tunnel. I'm using the original gearbox mounting bobbins which are quite small, but I did have to
trim a little bit of rubber off the sides of them as the mounting points on the box are quite wide, so a very tight fit
I like what you have done with the gear selector - I was wondering how I was going to do that.
BTW - it is an M52
Gearbox from top:-
Nickp
| posted on 8/11/11 at 10:09 PM |
I think your chassis must be a fair bit bigger than mine mate. My original gearbox mounts were small and squidgy so I went a bit OTT and fitted 2 x
Land Rover engine mounts back there. Clearances are so tight down the tunnel I wanted to keep it all nice and stiff. Glad you like my gearchange
solution - simple, but seems to work a treat.
