SteveWallace
posted on 9/2/12 at 01:27 PM |
Horn and Fog Light Swtches question
Just a quick question...
Is there any IVA or electrical reason why I could not use the windscreen wash/wipe stalk on my Sierra column to work my rear fog light and the horn.
I will not need it for its intended use as I will not have a windscreen.
I can wire the stalk so that all wiper positions would switch the rear fog light on (and energise the light on the dashboard) and the wash position
(which is spring loaded and would not stay on unless held in place) would work the horn. Of course, I would have to label the stalk accordingly to be
IVA compliant, but thats not a problem.
loggyboy
posted on 9/2/12 at 01:52 PM |
Cant see why not, although having 3 positions for a fog light may be considered to 'cause confusion'.
adithorp
posted on 9/2/12 at 03:02 PM |
No reason as long as it'smarked corectly.
http://jpsc.org.uk/forum/
SteveWallace
posted on 9/2/12 at 06:36 PM |
That what I thought. I'll give it a go and see what Mr IVA says (in about a years time).
I did think about the 'cause confusion' point, but hopefully as long as its labelled properly it should be OK, plus it will be obvious
when the fog light is on due to the light on the dashboard.
