aliwizard
| posted on 19/2/13 at 02:15 PM |
suspension settings
hi can anyone help with the suspension settings on my velocity xt it need to the caster ,camber ,ride hight settings, I am using ford Cortina uprights
and it is bike powered cheers.
| posted on 19/2/13 at 08:08 PM |
Before setting up the suspension check the crush tubes in the wishbone bushes are not too short (a known Luego problem that has been covered several
times). if there is any squeeking from the suspension it's likely to be caused by tight bushes . As for settings aim for around 5 to 7 degrees
castor 1 degree negative camber and 1mm toe in . If you can check it make sure the rear does not to out. IIRC my front ride height is 3.5" and
the rear 4.5". Another possible Luego problem is the Sierra column bush in the bulkhead sometimes isn't exactly at the correct angle in
relation to the column and can cause the column to bind reducing the self centering to some extent. A self aligning bearing greatly improves things
aliwizard
| posted on 24/2/13 at 12:02 PM |
self centreing bearing
thanks for your reply just been out for first run and have found the column bush has come out pushed it in again had another run it came out again
as you say this may be a alignment problem whats the best way of fixing this problem,or is fitting a bearing the only way and how would you fix the
bearing cheers .
| posted on 24/2/13 at 12:19 PM |
If you look at the Sierra bush when it's in place in the bulkhead you will probably find the bracket isn't at right angles to the column,
short of cutting out the bracket or realigning the column the easiest solution is to fit a self aligning bearing, IIRC some of the brackets are fitted
to the engine side of the bulkhead and some into the car. My Luego has it fitted into the engine bay , it is smaller than the bearing and needed a
small adaptor making up to allow the bearing to fit . It's been covered several times so worth doing a search if it's working . I think
?? the bearing came from Simply Bearings at around a tenner
