Thatcher
posted on 22/2/13 at 09:31 PM |
Brakes, 4 pot calipers for haynes roadster/Sierra uprights
Hi all
I'm at the stage of sorting out my caliper options for my haynes roadster using sierra uprights, I wanted a small 4 pot caliper and come across
metro turbo front calipers as they come with spacers so they can be used with vented discs. I have disscoverd that the bolt holes in the caliper and
upright line up to (bonus) I will have some discs soon so can check for fit and will post my findings once I have done some tinkering.......
Tony....
posted on 23/2/13 at 09:34 AM |
You really want to think hard before going down this route as there is little or no advantage.
Smoking Frog
posted on 23/2/13 at 11:00 AM |
Well I for one would be interested in the outcome. Don't be put off without good reason.
Eddie
posted on 23/2/13 at 11:34 AM |
The good reason is to do with the total effective hydraulic area of the callipers --- workout the area of a piston in the Metro
calliper x2 then work out the are of a Sierra calliper piston .
NB The area of only 2 piston in the Metro calliper not 4 --- Newton's Law applies every force has an equal and opposite reaction.
The Metro calliper will only exert about 0.75 of the force of the Sierra calliper at the same hydraulic pressure.
[Edited on 23/2/13 by britishtrident]
Thatcher
posted on 26/3/13 at 09:30 PM |
4 potcaliper on sierra front upright
Hi all
Just a line to update my progress on this subject, have made some new dummy spacers to replace the ones in the calipers that are now 14.5mm thick as
to the old thickness of 11mm then machined 4mm off the inside face of the mounting lugs on the caliper. It now goes over the sierra disc nicely but
may have to machine 1mm to 1.5mm off the mounting lug on the sierra hub carrier, will do this tomorrow and will post my findings soon and have some
pics to help.....
Ta for now....
Tony T.....
b14wrc
posted on 28/3/13 at 12:16 PM |
Post some Photos please.
I went down the brembo 4 pot route....
Rob
20vt powered rear engined locost
CNHSS1
posted on 28/3/13 at 01:31 PM |
the baby Scimitars, SS1s, late Sabres etc, came from the factory with the Metro 4 pot caliper as std, albeit the solid disc version.
Its compact and reasonably light even for an iron caliper, but the main issue is small pad area (about half a sierras) and not a huge choice of decent
pad material.
on the small scimitars, pad fade is a major problem, often so pad it boils the fluid too, most go to chevette based uprights and carlton vented discs
and Volvo calipers as a result, but its a heavy old setup.
don't let it stop you of course :-)
Thatcher
posted on 21/4/13 at 05:31 PM |
Hi guys
Well I have almost done it just need to fill and redrill the mount holes on said caliper and the job is looking good. Here is a link to my photos so
you can see how I got there...
http://s1365.photobucket.com/user/tony1968cars/slideshow/
