Rusty8888
| posted on 9/7/13 at 05:46 PM |
Viento Rover V8
First up.. I'm new - hello!
I have joined after about 5 years of Viento ownership but it has been off the road for the last 2 and now it is time to get it back on the road, the
trouble is the engine though.
It has a Rover V8 twin plenum with an early fuel injection system which it looks like the previous owner dropped straight in from the doner. After
seeing lots of pictures of other Rover V8s I was wondering what I could strip off it and replace to make it more reliable and presentable\less
cramped under the bonnet.
Thanks in advance
scudderfish
| posted on 9/7/13 at 06:14 PM |
Welcome
My V8 originally ran on a Weber carb from the donor Capri. I converted it to EFI a few years ago. There is no room under my bonnet so I ended up
with a 4 barrel throttle body on an Offenhauser 360 carb manifold. There are some before and after pictures here
https://plus.google.com/photos/107546850034467009420/albums/5406584324636010353
I got to know about it from here
http://www.spagweb.com/v8mini/gallery/05/01_efi_compare/
There are also photos of just about everything ever fitted to the RV8 here
http://www.mez.co.uk/ms12.html
Regards,
Dave
| posted on 9/7/13 at 06:19 PM |
It's possible to use 4 throttle bodies controlled by a Megasquirt ,Snuggs has converted his Viento using a Boxer manifold.
IIRC Wilkingj had a manifold for sale recently
kenton
| posted on 9/7/13 at 07:30 PM |
I used to run a twin plenum with the standard ecu in my viento. Mine came straight from the doner and i put 20,000 miles on it before fitting an
emerald k6 two winters ago. This years upgrade was a new 4.6 stage 2 from V8 Developments.
It was rolling roaded in april and so far ive covered 6 k miles, mainly with SKCC.
I still have all the parts from the old setup.
Whats your location?
Kenton
Irony
| posted on 9/7/13 at 08:43 PM |
Welcome to the madhouse. We need more and more Viento owners on here. Where abouts are you?
[Edited on 9/7/13 by Irony]
richardm6994
| posted on 10/7/13 at 07:03 AM |
this is my 3.9 rover v8 which I have just finished;
dizzy gone - replaced with megajolt and coil packs
electric fuel pump
electric water pump
small alternator
full build diary;
http://www.locostbuilders.co.uk/viewthread.php?tid=177481
[Edited on 10/7/13 by richardm6994]
Rusty8888
| posted on 10/7/13 at 10:24 AM |
Wow thanks for the replies!
I am based in Kent nr Sevenoaks and the car had a bit of use before I decided to leave it standing for far too long as it was a bit unreliable
(overheating) and uncomfortable to drive (I am 5'6" and need to bring the seat forwards...I liked the V8) so now it has turned into a
project.
Thanks for the pictures, links and suggestions I am going through them now and will no doubt have more questions following on from them...
