andy o
posted on 6/8/13 at 08:46 PM |
IVA for a write off ??
if you buy a kit car which was declared a write off and so has no registration due to being a type/class B so cannot be put back on road.
now if this can be repaired and then made to look like its just been built could it then have a vin number and go for an IVA test?
what paperwork is needed for the test?
be nice to have the car legally on the road
thanks
andy
AdrianH
posted on 6/8/13 at 08:56 PM |
Would you be using the car as a donor, then what would be the difference to any other car as a donor, you would get another VIN number and have to go
through the IVA as before?
Adrian
Why do I have to make the tools to finish the job? More time then money.
andy o
posted on 6/8/13 at 09:04 PM |
the car chassis damage is a very easy repair and so the it would basically be the same car.i have not put a car though the iva test and have read that
the tester wants photos and receipts and paperwork for the car.
I would have none of this and so not sure of if the car can be presented for the test
Ben_Copeland
posted on 6/8/13 at 09:22 PM |
You'd be better off getting a new chassis and put all the bits from that car onto the new one. Take pictures as you go and you'll have
plenty of build evidence etc.
There's a reason why it was declared cat B.
Make your own receipts, its easy enough.
[Edited on 6/8/13 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
posted on 6/8/13 at 09:43 PM |
You need a new chassis and go for IVA as a new build.
Then DVLA with a V55 and a Built Up Vehicle Inspection Report. V627/1
chrism
posted on 7/8/13 at 12:00 AM |
I thought class B and A write offs were only supposed to be sold to registered companies and had to be either broken for parts or crushed, I didnt
think that they were allowed to be put back on the road.
If that is still true then it would be as people have said above, you would need a new chassis and then transfer all of the running gear across, with
photos taken from start to finish to show what has happened. Im also guessing it would have to be a Q plate and not an age related reg as you wouldnt
get a V5 of the donors details since it is a class B write off.
One other thing to make note of is proving engine age, depending what type of engine it is if its one that should be using the older non cat emissions
you will need proof from the manufacterer of the engines age as again you wont have a V5 to show what car the engine came from.
A little hard work never killed anyone, but why take the risk!
AdrianH
posted on 7/8/13 at 05:21 AM |
There was a very similar thread before that needs to be gone though,what your asking is not impossible.
http://www.locostbuilders.co.uk/viewthread.php?tid=178703
Adrian
[Edited on 7-8-13 by AdrianH]
rhinopower
posted on 7/8/13 at 01:48 PM |
VIC check is all you need. Its not your fault the company that dealt with the salvage of the vehicle sold it on complete.
Mark Allanson
posted on 7/8/13 at 02:23 PM |
Er, not quite. The only way that chassis can go back on the road is by lying to DVLA by saying it is a new one and have steel receipt to
'prove' it. You can use all the mechanical parts saying you used the old vehicle as a donor.
Before commencing any work, you could have appealed the category to make it to Cat C (which it clearly was as you were able to repair it)
rhinopower
posted on 7/8/13 at 02:25 PM |
No you are wrong. Any car with a "VIC MARKER" wether it be A/B/C needs a VIC test.
chrism
posted on 7/8/13 at 04:23 PM |
Just because the vehicle was sold on when it should have been broken up doesnt automatically change what can be done with it, just the same way that
if someone sold a kitcar that was registered incorrectly (i.e. A Porsche replica still registered as a Beetle) the new buyer wouldnt be let off for
the incorrect registration they would then be the one responsible for it.
Mark Allanson
posted on 7/8/13 at 04:33 PM |
Categorising salvage is part of my day job - I think I might know a little about it
rhinopower
posted on 7/8/13 at 04:43 PM |
I know of several cat b cars that were put back on the road after a simple Vic check.
rhinopower
posted on 7/8/13 at 04:45 PM |
Not disputing that, vehicle would have to be correctly registered in the first place, but in the situation of the OP, he is simply verifying its the
same car and not another car with altered identity, and applying for the logbook.
