Author: Subject: zx9 coolant hose sizes
capri_big_jim
posted on 16/10/13 at 07:08 PM Reply With Quote
hello guys,
Iv googled it but cant find an answer....
I have a zx9r c engine and want to know the coolant hose size as I need to order some silicone hoses for my engine....
Jim
ian locostzx9rc2
posted on 16/10/13 at 07:44 PM Reply With Quote
pretty sure there 25mm as per most bike engines
YQUSTA
posted on 16/10/13 at 07:48 PM Reply With Quote
Agreed 25mm and 10mm
"If in doubt flat out"
Colin McRae
capri_big_jim
posted on 16/10/13 at 07:59 PM Reply With Quote
Thanks guys,
Iv seen that there is the standard reinforced silicone hose on ebay and also this vacuum silicone that also says for coolant....
would this be ok for the main hoses as it is more flexi?
Jim
40inches
posted on 16/10/13 at 08:10 PM Reply With Quote
Three ply silicone the minimum for cooling, don't hold much hope for the single ply lasting long on a cooling system running at 90 degree, at close to 1 bar pressure
capri_big_jim
posted on 16/10/13 at 08:17 PM Reply With Quote
thanks
the only reason i asked is cause it states coolant in the list of uses....
jim
