mike2704
posted on 8/11/14 at 09:47 PM |
edis/esc
Hi, Just a quick question for all you knowledgeable peeps, I am bidding on a ESC ignition unit and loom the seller says it would run a Zetec with bike
carbs but I thought it should be a EDIS and I right or am I wasting my money HELP!!!!!!!
Thanks Mike ![](/images//smilies/cool.gif)
19sac65
posted on 8/11/14 at 10:33 PM |
Esc will run it better than just edis
Esc will advance ign as reqd as it has a base map , edis will just sit at 10 degrees- limp mode
Its a cheap way to get a zetec up and running but esc was for escort and fiesta cvh so was never intended for a zetec
big_wasa
posted on 9/11/14 at 08:19 AM |
I've played with no end of them.
Only any good if your on a tight budget as the ignition curve is for an 8v engine and the Rev limit is low.
