Author: Subject: Velocity XT Prop Length ( Zetec, MT75, 7.5inch Sierra Diff
saigonij
posted on 5/12/04 at 06:15 PM Reply With Quote
Hi all,
As above,
can anyone tell me the exact measurements i need for my prop shaft. Also, anyone recomend a good place to go to , to get it done?
Thanks,
wilkingj
posted on 5/12/04 at 07:36 PM Reply With Quote
Well the distance depends on where you bolt the engine and box in the front bit of the car!.
I believe you measure from the Lip of the oil seal in the gearbox to the flat of the Flange on the diff. As a worst case draw where you measured from on a bit of paper with diagram.
I assume this is to get you propshaft made / shortened.
I am sure someone will correct me if I am wrong.
As an afterthought, Ring Luego tomorrow and ask them.
[Edited on 5/12/2004 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
helen & phill
posted on 5/12/04 at 07:38 PM Reply With Quote
Don't know abput the measurement. Ive got a different setup but I have fitted everything to get the measurement. That way I Know it's right.
I'm about to order mine from Bailey Morris http://www.baileymorris.co.uk/ they make them brand new no exchange at £125 +VAT. May be a bit on the expensive side but it is a brand new item and their quality looks good. Also they were recommended by Luego.
But if anyone else has a better supplier/suggestion I might change my mind.
http://www.velocityxt.co.uk/
posted on 5/12/04 at 08:05 PM Reply With Quote
Have used Bailey Morris in the past, can recommend thier services . Not cheap but first class products.
