Luego Sportscars Holland
posted on 1/1/05 at 04:03 PM |
2001 2.0 Zetec + Type 9 gearbox!!
Hello everybody,
Who knows the following:
If you want to use a 2001 2.0i 16v Zetec together with a type 9 gearbox and you want to use the standard 2.0 flywheel which friction disc, pressure
plate and release bearing you need to get it all working??
Thanx.
posted on 1/1/05 at 04:35 PM |
this has been covered before i seem to recall. Not sure where, and zetecs arent something i know anything about. Try searching for zetec! should pull
up some results.
stevebubs
posted on 1/1/05 at 05:03 PM |
Not sure you can use the 2.0 flywheel - think you'll need to move to the 1.8 one (I have)
IIRC the plates you then need are from a 1.8 CVH Sierra, as is the starter.
Bought all my stuff from Dunnell - bit cheaper that Raceline et al.
HTH
Mave
posted on 1/1/05 at 06:22 PM |
Michel,
I found this in my archive (thanks to www.zetec-cat.co.uk):
The standard 2.0 litre Zetec flywheel can be used however this is quite heavy. This will require a standard 2.0 Zetec clutch and a clutch release
bearing from a 1971-88 Ford Transit 2.4/2.5 diesel (Quinton Hazell part CCT303)
I hope this helps.....
Marcel
fastenuff
posted on 1/1/05 at 11:14 PM |
try these chris or dave's and
read somewhere that the relaese bearing of a cpari could be used, there are 2 types 20 spline or 23 spline ( ford no. 6124271 and 6124270, did spend
half an hour at ford looking at photofile sheets)
Ingmar
